Ok, so I am tweaking my '80 special with the Mikuni carbs fitted for the '80 model.
Original main jets in order were 1- 110mm, 2-120mm, 3-120mm, 110mm, per the factory original setup. I assume we are heavier on 2 and 3 to cool them down a bit. The size increase for these carbs appears to be 5mm increments.
Ok, so the formula most agree on when jetting up is, add one unit for every performance mod, take that total ,subtract one, and that result is the number of steps up in increase in the jet size.
So, I added a K&N filter, Accel Super Coils and a Mac 4-ito-two exhaust. 1+1+1=3-1=2. So I should rejet two sizes up in each carb, right?
With what I had around the shop, I moved 1 to 120mm, 2 to 125mm, 3 to 125mm and 4 to 120mm. I didn't have any 130mms handy.
Packmule runs great, with very little popping on decelleration.
I very respected and expert mechanic suggested that I even all mains to the same jet value.
He also thought about increasing the pilot jets from 42.5mm to a higher value.
What has been your experiences with the '80 Special carbs and running main jets to all the same size? Performance? mileage?
Thanks,
greg
Thanks,
greg
