Factory Tool set
  • Crazcnuk
    • 2980
    • Hinton, AB, Canada
    Factory Tool set
    I am just trying to get info on what all would have come in the original toolset. I would like to put together a set to have on the bike, you know, in case I come across any stranded hardleys, or euro bikes!
    What I have, so far is:
    1- small phillips screwdriver bit
    1- large phillips screwdriver bit
    1- slotted screwdriver bit
    1- screwdriver handle
    1- Oil level gauge
    3- allen keys ( not sure size, but assume 6mm, 4mm, ??
    1- pliers
    1- wrench handle extension
    3 - single box-end wrenches 17mm, 22mm, 24mm
    1- sparkplug wrench
    3- double open ended wrenches, 8&10mm, 11&12mm, 13&14mm???
    1- Spring hook (not sure what this is)
    1- Spring hook lever (or this)
    1- tool bag
    I have a few pieces around from bikes in the past, and some can be scrounged on Ebay or garage sales. Just need to know what all is supposed to be in there.
    '05 ST1300
    Hey CrazCnuk,
    Did a search for "bike tool kit",
    Found This thread with photo of OEM kit.
    and This thread discussing what tools folks bring ,
    and there's a tech tip, I think in the MISC section about the ULTIMATE TOOL KIT!
    • Crazcnuk
      • 2980
      I already had a pretty good picture. A set was for sale on Ebay, it went for $51, I think.
      He did not really explain the tools, though.
      The factory tools weren't the best, but they can save the day, in an emergency, and they fit in the toolbox.
      I now know that the spring hook is for holding up the rear caliper, when you take the back wheel off.
      The lever is used to lift the swingarm up so you can get the axle past the muffler?
      '05 ST1300
      • Crazcnuk
        • 2980
        Here is what I have, so far. Items with '?' I am not sure about.
        Open end wrenches
        8mm x 10mm
        10mm 12mm
        14mm x 17mm ?
        Box end
        22mm
        24mm
        27mm
        handle extension
        Screwdrivers
        1 small Philips
        1 large Philips
        1 Slotted
        Handle
        Alan Keys
        4mm ?
        6mm ?
        Misc
        Sparkplug wrench w/ cheater bar
        Spring Hook ( for rear caliper)
        Oil guage
        Spring hook (Shock adjuster)
        Pliers
        bag
        '05 ST1300
        • Crazcnuk
          • 2980
          Updated with new information
          Open end wrenches
          8mm x 10mm
          10mm 12mm
          14mm x 17mm
          Box end
          19mm
          22mm
          27mm
          Handle Extension
          Screwdrivers
          1 small Philips bit
          1 large Philips bit
          1 Slotted bit
          Driver Handle
          Alan Keys
          5mm
          6mm
          Misc
          Spring Hook ( hanger for rear caliper)
          Cable to hold up rear swingarm (std only)
          Oil guage
          Pliers
          bag
          I assume if you went to any large bike wrecker, they likely have a box full of these (junk) tools you could paw through to make up a reasonable starter kit.
          '05 ST1300
          • TTrottman
            • Aug 2025
            • 1
            I have the original set all be out there tomorrow and can take a look what is in it if you would like.
              • 7792
              The "Phillips bits" SHOULD be JIS bits! There is a difference and the JIS will not strip the heads of the OEM screws like a phillips will.
                • 3192
                Pretty sure that in the 18 or so years since this was posted that he has the situation handled...lol
