1982 xj1100 headlight problem
  • bbbiscuit
    • Jul 2007
    • 1
    • Vancouver, Wa
    1982 xj1100 10k miles. the headlight works and sometimes it doesn't. the problem seems to be getting worse. removed the lamp and tested the plug with no apparent power during one of its episodes. i have also had an intermittent problem with the bike quitting when pulling in the clutch and putting into first gear. maybe a safety switch ? are these two problems related?
  • Axel
    • May 2007
    • 869
    • Renfrew,Ontario
    No headlight
    I had an intermittent headlight thing going a while back . A friendly fellow went straight to the fuse block and the fuse was faulty . It looked good at a glance but something was actually melted inside . We also used a dremel tool with wire brushes to clean the fuse holders . They are open to the air and get less conductive over the years . Better than new fuse blocks are available . I read about them here somewhere. Oh , and The PO had used a longer fuse than OEM - maybe that started the problem . Good luck . Axel
    XJ1100K
    Avon rubber
    MikesXS black coils
    Iridium plugs w/ 1k caps
    MikesXS front master
    Loud Horns (Stebel/Fiamm)
    Progressive fork springs
    CIBIE headlight reflector
    YICS Eliminator
    • Axel
      • May 2007
      • 869
      • Renfrew,Ontario
      similiar thread
      Use the search to find similiar threads or just info about xj11's.
      Lots of people have them . This is a little different problem but has links and lots of info .
      my xj1100.....still having problems!
      Hope that works . Axel
      XJ1100K
      Avon rubber
      MikesXS black coils
      YICS Eliminator
      • Axel
        • May 2007
        • 869
        • Renfrew,Ontario
        XJ1100K
        Avon rubber
        MikesXS black coils
        YICS Eliminator
        • Axel
          • May 2007
          • 869
          • Renfrew,Ontario
          safety switches
          Some of my safety switches work and some are disabled . I was surprised at the extent of the wiring and diagnostics . I'm sure the clutch lever switch is disconnected or shorted to cause an "ok" condition . So there was a problem there for the PO . Many electrical problems can be righted by cleaning connections.
          Axel
          p.s. where you from bbbiscuit ?
          XJ1100K
          Avon rubber
          MikesXS black coils
          YICS Eliminator
          • frogdink
            • Feb 2007
            • 146
            • Richmond, Maine
            i had the exact same deal and it was the fuse that was all but blown, changed it now its always fine
            1982 XJ1100J
            Sold:
            1974 RD200
            1975 xs500
            1985 Honda XR350
            • DELL82
              • May 2006
              • 260
              • Houston, Texas
              Had the same problem, but I have already changed the fuse block to the mini spade type, so that was not the problem. The XJ has a large lighting module under the seat that has a plug connected to it with eight connections. Cleaned that up and problem went away. PO had removed and wired around two of the contacts because of excess corrosion.
              Good luck
              Dell82
              Dell82
              Houston, TX
              82' XJ1100J Maxim "LASERMAX"
              SOLD 86' Kawasaki Voyager XII, 1200cc SOLD
              SOLD 82' CB450SC Nighthawk, FOR SALE SOLD
              SOLD 82' CB450SC Nighthawk, parts bike SOLD
              • Rubin
                • Apr 2003
                • 115
                • Windsor, Ont
                Found this on a search for ways to upgraded the headlight and wiring:
                Looks interesting, though discontinued. They might have stock available still, will email them to find out.
                1984 XJ1100 - 79 cams, XS850 FD, XS triple tree/euro cafe bars, hydraulic clutch, bar end mirrors, yamaha R1 rear mono-shock
                1972 CL350 - clubmans, Mike's XS coils/condenser, '98 Yamaha R1 rearsets (If I can find some at a decent price)
                • Rubin
                  • Apr 2003
                  • 115
                  • Windsor, Ont
                  No luck, discontinued and no leftover stock. Too bad.
                  • scott0757
                    • Jun 2007
                    • 130
                    • Syracuse, NY
                    Seacrh for a Forum thread named fuse block and you can get a spade type replacement from TCat.
                    [Fuse Block Thread
                    I just installed one on my 1980XS1100SG this past weekend and it went easy. The two extra slots in this 6-fuse holder hold the spare fuses.
                    Past Rides:
                    1969 OSSA 250 Pioneer
                    1979 XS650 Special
                    1978 Honda CB750K
                    Current: 1980 XS1100SG
