exhaust systems?
  • exhaust systems?
    I just replaced my exhaust system and I no longer have the crossover tube installed. Do I really need to have this tube. I have not tried to start the bike because I am having coil problems.
    So before I start the bike will it be ok?
    If the replacement pipes are 4 into 2 and designed for the XS11 you will be ok but I would re-sync the carbs. You will however loose some of the exhaust savaging effect that the cross over pipe was there to promote.
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
      The cross-over helps with low-mid range torque. Higher RPM will be fine. These bikes have so much torque down low that you'll be good to go.
      Pat Kelly
      <p-lkelly@sbcglobal.net>
      1978 XS1100E (The Force)
      1980 XS1100LG (The Dark Side)
      1999 Suburban (The Ship)
      1994 Dodge Spirit (Son #1)
      1968 F100 (Valentine)
        79XS11F, did you perhaps mean "re-jet"?
          I actually meant re-sync. My own experience is that just about any change to the air supply system,carbs or exhaust requires a re-sync. Most 4 into 2 and even many 4 into 1 after market pipes don't require re-jets but that is of course depends on the brand.
          For me re-syncing is a for sure and re-jetting is a "maybe"
          Rob
          1978 XS500E
          1981 Suzuki GS1100
            I was thinking the same thing, Prom. When you think of it, if low-range torque is affected by the change, the pressures at the manifolds might also be differentially affected.
