Why would I get less than 20MPG on an XS1100?
  • markjs
    • 86
    • Port Townsend, WA
    The floats are resonable close to right and it ain't leaking gas, it's timed and the vaccum advance works, but it gets less than 20MPG and runs terribly rich......what gives?!?
  • TADracer
    • 1417
    • Kenner, Louisiana USA
    Sounds like time to clean those carbs, check your jet sizes, do a good syncronization and a good tune up. If you are right, you should be getting over 30 MPG
    Mike Giroir
    79 XS-1100 Special
      • 5048
      Are there any spots in the rpm range that are sluggish ? (if so, use new plugs and run at that range for 10 minutes and check plugs) Does it pull hard in the upper end or is top speed less than 100 mph? How do the plugs look? How is your exhaust system, including the welds, baffles, and crush gaskets? Any of those things (and more?) will give you clues about what is wrong.
      • Snow
        • Oct 2002
        • 1041
        • Tallahassee, FL
        Has it always been like this while in your possession? I'd also suggest checking your jets - it's possible you may even have the wrong style that feeds too much fuel into the mix. Does she leak fuel from the carbs when not running?
        • prometheus578
          XS-XJ Super Guru (RESIGNED)
          • Aug 2004
          • 4012
          • Olympia , Wa.
          Might be time to diet?
          Runs rich... Also check the airfilter.. might be really dirty.
          Simple things... Is it running strong on all four cylinders? Some people can't tell the difference.
          Like the other's have mentioned...
          Yes, check float height and while you're in there, check that the jets are the corret size. What's the idle mixture screw set at?
          • Snow
            • Oct 2002
            • 1041
            • Tallahassee, FL
            Oooh ooh ooh, Prom, you reminded me of something. Get the bike running for a minute or two and spray some water on each individual header pipe - it should roll off the pipe due to the intense heat. If it just sits there and steams or does nothing, you just found a dead cylinder. Then you can do a couple tests to figure out if it's fuel or spark related.
            • prometheus578
              • Aug 2004
              • 4012
              • Olympia , Wa.
              Should instantly sizzle away.
              I always use a spray bottle of 409 cleaner. Seems to be always handy.
              Oh, and Snow...
              You need to start writing your graduation speech, or whatever.
              It needs to be profound, insightful, but most of all, humble.
              (We've been watching)
              • Snow
                • Oct 2002
                • 1041
                • Tallahassee, FL
                Originally posted by prometheus578
                Oh, and Snow...
                Lol, I was wondering if anyone had noticed recently - I'll try to make #1000 good
