K&L jets
  • red bandit
    • 970
    • central michigan
    K&L jets
    With all the talk about K&L jets being junk, (I thought so too) I thought I'd let you know my weekend results. I rebuilt a customers carb with his supplied K&L kits. Mains 137.5 and 42.5 pilot jets, float seats and needles, idle mixture screws. Sync came right in and idled nice and smooth, pulled strong thru complete rpm range. Bike runs great.
    For what it's worth !!!
    79 SF parts bike.
    • 5069
    So do you think that going down one size on the pilots helped? I was thinking stock is 45's for the 78 and 79 models. All else is stock on the bike you worked on?
    • red bandit
      • 970
      • central michigan
      45 was stock for 78 but not 79. 42.5 was in the carbs when I took em apart. Stock bike. Also installed air jet from kit.
      79 SF parts bike.
        Hey Red,
        Did the pilots have the vent holes in their sides or not? IF they had the holes, then they may have been the correct style. Prom has posted that K&L made several styles, and many times folks end up ordering the wrong kits, and they get the later styled pilots with NO HOLES which run too rich and cause the idling and poor low end performance! Glad to hear it was a successful repair/maintanence session!
        • red bandit
          • 970
          • central michigan
          They had 6 holes in the sides just like OEM.
          79 SF parts bike.
          • Stralya
            • Apr 2006
            • 791
            • 'Blotto Grotto' Wodonga, Victoria, Australia.
            Hey Red,
            What do you supply your customers with if I may ask?
            I've just spent a motza on rebuilding my '78E's cylinders, pistons, rings and head (with the indispesable assistance of fellow excessive petejw, thanks pete!) and now that the engine is perfect, the carbs little problems which weren't really noticable before the rebuild, are pretty noticable now.
            I don't want to make any blunders before I start so what brand rebuild kit would you use?
            I'll understand if you want to keep this info under your hat.
            Thanks,
            Dan Tyson (Stralya)
            Automotive Imbecile.
            Proud owner of 'The Swiftcicle'. (Swifty for short)
            '78E Full Vetter Dresser.
            1196 Big Bore Kit.
              • 5069
              The ones that have the outlet hole downstream of the air bleed holes are the ones to use. Micuni also makes pilot jets where the outlet hole is upstream of the air bleed holes and I have never had any luck with those, although the ones I tried were the #45 variety (way richer than normal #45.)
              • red bandit
                • 970
                • central michigan
                Skids...Right
                I usually don't use "kits" I change (new) the float needles, (PNM or Mikes) clean and use the jets that are in the carbs. Most people don't want to spend the money for me to clean em much less for parts. I will put in what ever they want. The carbs on my bike doesn't even have float needles changed.
                79 SF parts bike.
                  Hey Strayla,
                  See this recent thread about carb kits! , might find it useful!
                  • red bandit
                    • 970
                    • central michigan
                    The kit # is:
                    XS1100 1979
                    CARB REP KIT: K-622
                    18-2581
                    I don't know where the guy got it from or how much he paid.
                    79 SF parts bike.
