True TDC...again
  • TADracer
    • 1417
    • Kenner, Louisiana USA
    True TDC...again
    Hi everyone. Its been awhile since I have posted anything of substance so I thought this would be appropriate with all the talk about TDC.
    79xs11sf's thread "True Tdc" got on to other things but I recently turned 30K miles and did some cam checking with a degree wheel and dial indicator. I have started to write up my findings to post here on the forum but I am not finished all that yet since I plan to tinker with some cam timing. But, the next paragraph is what I had written down so far about finding true TDC.
    _________________________
    Top Dead Center on the #1 piston at the very top of the compression stroke. Locating TDC is critical to your measurements since everything is measured off of the crankshaft. Also, as little as one or two degrees can have an effect on your cam timing. Some use a soda straw in the spark plug hole and rotate the crank until it stops rising out of the hole to locate TDC. BUT, this method could leave you several degrees off because of piston dwell at the top of the cylinder while the crank throw and rod swing past TDC. So I used a piston stop and degree wheel instead. I installed a wire pointer and degree wheel as close to TDC as possible (using the timing plate as a reference) and then I installed a piston stop on the spark plug hole on the #1 cylinder. I ROTATED THE CRANK to just before TDC (about 20 degrees) and screwed the stop in until it just touched the top of the piston. I recorded the reading on the degree wheel and then ROTATED THE CRANK the opposite way around until the piston touched the stop again and recorded that reading. Then I added the two numbers together and divided by 2 and recorded the answer. I RELOCATED THE WIRE POINTER to line up on the degree wheel with the mark that represented the answer. To check, I ROTATED THE CRANK in the opposite direction until the stop touched the piston again and verified that the pointer was on the exact degree on the opposite side of TDC. If it does not come back to the same degree on the opposite side of TDC, start over. If it does, then simply ROTATE THE CRANK until the pointer lines up with zero on the degree wheel and that is true top dead center. Make sure you do not bump the pointer while you work.
    __________________
    This method works every time, is easy to do and puts you dead on the mark. It only took about ten minutes to set up. Naturally, if your valve cover is not off so you can see the cams you need to make sure you are coming up on the compression stroke by placing your finger over the spark plug hole while you rotate the crank. When you feel the compression coming out past your finger you are approaching TDC. If you dont have a piston stop you can easily make one with a bolt and an old spark plug body. If you do not have a degree wheel, type 'motorcycle degree wheel' on Google and you will find some that can be downloaded. Print one up on sticky paper and make one on a piece of heavy cardboard or sheet plastic. A 6" or 7" diameter wheel is perfect and gives you enough clarity between marks to set up down to 1/2 a degree. A pointer is a simple as a piece of wire with a point that is bolted to the engine block. I used a wheel by MotionPro. If you have such a degree wheel that can take high RPM, you can set your ignition timing very accurately too.
    Mike Giroir
    79 XS-1100 Special
  • 79XS11F
    • 3563
    • Ottawa, Ont. Canada
    That would work but why use a piston stop as compared to a dial gauge? Would it not be easier and equally as accurate to use ether a bolt on or spark plug type dial gauge. Works the same way .. as soon as the dial stops moving while the piston is moving upward the crank is in the dwell stage and leave s the dwell stage when the dial starts moving again. Split the difference in movement at the fixed pointer and you have TDC.
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
    • TADracer
      • 1417
      Really, any way to split the dwell difference accurately should work.
      I used a piston stop for two reasons. 1, I had one handy and 2, it provides a solid stopoing point instead of trying to read a dial while you are turning the motor over by hand.
      Mike Giroir
      79 XS-1100 Special
      • LoserShoes
        • Apr 2005
        • 524
        • Bangor Maine
        Also the stop takes up all the clearances equally in both directions, which may or may not be significant.
        Steve
        73 Yamaha DT3 - DirtyHairy
        CZ 400 MX'er
        68 Ducati Scrambler
        RC Planes and Helis
        • mro
          • 4276
          • Hayward, California
          Hmm....I resemble that remark
          On a customers engine I whip out all the goodies when wonking on one, crow bars, crescent wrenches, BIG momma hammers...after all there paying
          mro
          btw, did you get hold of some slotted cam sprockets?
