Intresting tidbit
  • Intresting tidbit
    I was just having a smoke and reading the "Vehicle emission control information" tag that is attached to my locking side cover.
    It says that the engine should be set to idle at 1100 RPM
    ignition Timing 5 degrees BTDC
    Gasoline grade regular (leaded) octane 91 MINIMUM
    HMMM ... Regular gas around here is like 87 at best and I have been trying to get my bike to idle at about 1000 RPM
    When i am done with this head job I will set the idle faster and use the higher grade gas to see if that also helps the engine run better.
    Is anyone else using high test gas day in and day out? How many have their idle set that high?
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
    The RM values were caculated differently then. Mid grade will be just fine. Anything greater is a waste to your pocket book. As for the idle, the 1000-1100rpm is just fine.
      "Terminology..."
      When i am done with this head job...
      Please refer to this as a "Valve Job", or.. getting some work done on the head, etc.
      (I'm a divorced guy, and it's been a while...)
        Having a smoke and a head job sounds about right to me. I don't know why he tossed in that other info on timing and fuel.
        I hate signatures. Too many cars and Bikes to list here.
          The VALVE JOB is done and I am having another smoke LOL LOL
          Why did they change the way octane is determined??
          Rob
          1978 XS500E
          1981 Suzuki GS1100
            Change
            Could be because there is no longer lead in the gas and now there's alcohol
            Drilled airbox
            Tkat fork brace
            Hardly mufflers
            late model carbs
            Newer style fuses
            Oil pressure guage
            Custom security system
            Stainless braid brake lines
              Can't remember ......................but there is a long thread in here somewhere bout how all that is caculated.
