I have the head off my bike now in this on going effort to remove all question marks about why it dose not run as I believe it should. I want to know what is TRUE TOP DEAD CENTER. When I spin the engine in the correct direction I can see and feel the #1 piston stop moving upward and then it does nothing before starting back downward. There is about 2 or 3 degrees on the timing plate where this is the case. I can see that in the past the pointer has been removed because the paint at the screw is gone.
SO is TDC the middle of this range of no movement or at the beginning or at the end? I will guess that it is likely the middle but want to be sure before I reset the pointer.
Rob
Rob
