Head gasket question
  • Stralya
    • Apr 2006
    • 791
    • 'Blotto Grotto' Wodonga, Victoria, Australia.
    When replacing the head gasket and bottom cylinder gasket, is it wise to install them dry?
    Dan.
    Automotive Imbecile.
    Proud owner of 'The Swiftcicle'. (Swifty for short)
    '78E Full Vetter Dresser.
    1196 Big Bore Kit.
  • red bandit
    • 955
    • central michigan
    YES
    79 SF parts bike.
    • planedick
      • Mar 2005
      • 2068
      • Yorba Linda, California
      Except for
      around the cam chain galley. You should use some Yamabond around the chain galley or it will probably leak later. Yamaha no longer has a seperate gasket for that area as it was eliminated and soemtimes leaks. PITA
      Drilled airbox
      Tkat fork brace
      Hardly mufflers
      late model carbs
      Newer style fuses
      Oil pressure guage
      Custom security system
      Stainless braid brake lines
      • Stralya
        • Apr 2006
        • 791
        Thanks guys. Hey planedick, I assume threebond would do?
        Dan.
        1196 Big Bore Kit.
