Running rough when cold
  • Running rough when cold
    My bike was running like a dream . Just been synched and color-tuned . Previous to this I had ran a can of Seafoam though it over three tanks . It was like a new bike .
    Now - its hard to start ,even when warm . I need all kinds of choke to keep it running . I have had to turn up my idle . When cold it is missing I think sometimes . My exhaust is not completely tight at the mufflers and they may be bored out a bit as well .
    Any ideas ?
    XJ1100K
    Avon rubber
    MikesXS black coils
    Iridium plugs w/ 1k caps
    MikesXS front master
    Loud Horns (Stebel/Fiamm)
    Progressive fork springs
    CIBIE headlight reflector
    YICS Eliminator
    Could be that you've disturbed some sediment and rust from the tank, and it has found its way to the bottom of the float bolws and plugged up the wee orifices that feed the enrichener circuit. That, or that same sediment has now plugged up the low-speed circuits in one or more carbs. Either way, I'd say you need to go back into the carbs again.
    Ken Talbot
      carbs - YICS
      It runs fine with the choke on - right from start up . Its when I try to ease the choke off , it runs rough when cold .
      Could you please describe the process . Thanks . Axel
      XJ1100K
      Avon rubber
      MikesXS black coils
      YICS Eliminator
        Ax, I'm sounding like a broken record, but unscrew the idle mix screws another full turn(your colortune might not agree though..)
          Let it warm up for a minute or two, and then, with some water in a spray bottle, spray the header pipes to see if all cylinders are burning the same. You may have one or two that won't sizzle like the others.
          I agree that it sounds like a carb problem. The cold header pipes will tell you which ones.
            Switcheroo
            Tonight I went out and the bike ran great. Not a miss . It has had a chance to dry out after getting some rain . I also failed to mention a seafoam treatment a couple of weeks ago . Nice ride tonight though - riders on the storm .
            XJ1100K
            Avon rubber
            MikesXS black coils
            YICS Eliminator
              Re: Running rough when cold
              I trust you used a YICS tool to isolate the intake manifolds when you did the sync?
              Ken Talbot
                YICS
                Yes we did
                XJ1100K
                Avon rubber
                MikesXS black coils
                YICS Eliminator
                  rough running when cold
                  I've tried a few different things to try to narrow down the cause.
                  Next is a severe Seafoam treatment to help along any rust or gunk through the carbs . I have made contact with a guy with a shop who will give me space (and advice ) in his shop . He used to be a Yamaha mechanic .He says to Kreem the tank . He figures the carbs need to come off too . I will get a chance to work on my brakes as well . Cheers , Axel
                  XJ1100K
                  Avon rubber
                  MikesXS black coils
                  YICS Eliminator
                    fouled plugs
                    I guesss my plugs were fouled . I installed a new set of Iridium plugs and it runs like a rocketship once more
                    XJ1100K
                    Avon rubber
                    MikesXS black coils
                    YICS Eliminator
                      Ah,
                      But WHY did the plugs foul in the first place?? When the bike is running right, tuned properly, strong ignition, it shouldn't foul them! Folks get thousands if not 10's of k's out of plugs. SeaFoam and inline filters are a good plan! Wonder if because of the cooler climate that you might need a hotter plug? Good Luck!
                        fun and games
                        I had 3000 kms on the old plugs . I wonder if my mis-use of the choke contributed to the problem . I even forgot to return it on a few rides . I also wonder about my riding practices . I was more used to chucking along at 2500-3000 rpm than cruising at higher rpms . I now pay more attention to this and use lower gears for a faster engine speed . My Seafoam treatments may have me running a little rich as my last synch and color-tune were performed previous . Last I had a few mis - attempts at adjusting the cam chan tensioner but finally got this worked out .
                        TThe iridium plugs seem to work really nice -more bottom ,easy starts , more responce -so I'm happy for the moment
                        Axel
                        XJ1100K
                        Avon rubber
                        MikesXS black coils
                        YICS Eliminator
