Did some repairs...Down to 4 problems... I think
    #76
    Reg/Rect info!
    1J7-81970-60-00 RECTIFIER ASS'Y 1
    Below is the #'s listed for the "D" model, and it also has a different style plug vs.
    the above item.
    1T4-81960-92-00 RECTIFIER & REGULATOR ASS'Y (1T4-81960-91)
    Well, bust my britches, here's the Rec/Reg for the 78E
    1T4-81960-A0-00 RECTIFIER & REGULATOR ASS'Y (1T4-81960-92)
    IT's close, but not exactly the same. Geezer might be able to tell you whether it
    will work or not?
    BTW, you think that Geezer's Reg/Rect is salty, take a look at BikeBandit(OEM)
    4: RECTIFIER/REG ASY 13130-001 $204.01 for 80G!
    And here's PNM's "Universal Unit" and it doesn't even come with any plugs!?
    UNIVERSAL RECTIFIER / REGULATOR
    Fits XS750 - XS1100 For all 3-phase permanent magnet alternators. Replaces stock units. Regulates AC output voltage and rectifies DC charging current. 5 wire unit w/ 10" lead wires NOTICE: Please see return policy
    $95.00US EA. Part#24-2032
    So...you can see at these prices, why "we" endorse Geezer's unit, lifetime guarantee (his...not the unit's ) and with more robust internals to give stronger lower rpm power!
    • renegade_xs11g
      • 462
      • Mid-Michigan
      #77
      TopCat..........
      Holy cow, the info at your disposal........................
      Thanks, John
      P.S. SWMBO think the price is salty....NOT me!
      My Photo Bucket
      • renegade_xs11g
        • 462
        • Mid-Michigan
        #78
        Need to pick some brains...what's going on
        I stole the rectifier (from the 78 xs7502d) AKA 'little brother'
        installed on the '11'
        the headlight still didn't come on ......but.....
        if I unplug the rect then replug.....
        the headlight will come on.....
        even if I kill it b4 I unplug/replug
        This obviously isn't correct......
        but WHY will it come on only after it's plugged back in
        My Photo Bucket
        • renegade_xs11g
          • 462
          • Mid-Michigan
          #79
          Maybe, just maybe the tach wasn't working last weekend...
          it wasn't just a few minutes ago...
          now it is....don't know why it started to work
          all I have right now is a multimeter, not a test light
          can I test with a meter????????????
          My Photo Bucket
          • renegade_xs11g
            • 462
            • Mid-Michigan
            #80
            OK NOW HANG ON A MINUTE.....
            the alternator was unplugged, from behind the fuse box...
            I unplugged it to test the stator...forgot to plug it back in,
            still nothing work's,
            didn't look to see if tach was still working or not,
            2 bad rectifiers, and 2 bad RLU's, what would those odds be???
            something in the windings?
            hope not but.....what else could it be?
            My Photo Bucket
              #81
              Hey Renegade,
              As I've stated before, I'm no electrical Guru, Randy and several others are more knowledgeable than I. I don't know if Randy has had any experience with the 750 reg/rect, or Geezer for that matter? SO....can't tell you what's happening with regards to headlight coming on only after replugging it in?
              Yes, you can use the multimeter like a test light, in the VDC setting, so if you've got current readings then the circuit is working. IS your ALT cranking out the volts above 14 at 2500 rpm?
              • renegade_xs11g
                • 462
                • Mid-Michigan
                #82
                didn't even try to test with the meter...
                will have to wait til next weekend...
                sometimes I HATE driving a truck
                My Photo Bucket
                  • 5069
                  #83
                  Bad diode inside the harness? Try running your own wires.
                  • renegade_xs11g
                    • 462
                    • Mid-Michigan
                    #84
                    Hey SKIDS...
                    What do you mean 'bad diode'?????
                    and run my own wires from where to where?????
                    My Photo Bucket
                      • 5069
                      #85
                      Re: Hey SKIDS...
                      As I reread the threads, I think you should forget my comment. I cant follow what was happening when the light worked or didn't, or whether the disconnected clip had a play in it. (Its late here for me) Yes, later models have a diode, but yours must be working if you get light sometimes. I do know that you have to push a minimum current through a diode to make it work.
