I just cleaned and inspected the VM33 Mikuni smooth bore carbs on my 80G. Was kinda' fun cuz nearly every hole was either plugged or had junk in it .... so I pretty well knew it would purring or growling (it has a SuperTrapp too) soon. Put the carbs back on, flipped to prime and almost before I could hit the starter button, gas came pouring out of both vent tubes (not connected to the box) and the airbox itself. Hmmm ...... no way would it start or self correct the flooding.
I then took the tank back off, put it aside and decided to check for spark. Had plenty and it nearly started on three .... put the plug back in and it fired right up. Strong and snarly ....
just with the fuel in the bowls but no tank on. Wheww hoooo !!
Hoping that it had self corrected, I hooked the tank back up and it flooded again the same way.
All floats were set to 3/4 inch ... 18-19mm .... by whoever worked on it before me and I didn't mess with 'em. That is very high compared to the stock XS carbs as we all know .... which very well may be meaningless because the style of carb is quite different ..... BUT ....
Could the float level be set up so high that the fuel NEVER shuts off at all before gushing out the vent pipes OR because of an high float level, could the float drop be so long that the needle is getting jammed up and never seating? Needles looked good under magnification but could they still be bad? Does anyone know what the float level and drop spec for this type of carb should be? The PO said it ran awesome with these carbs on ... was due to an ignition problem that I ended up with the bike.
just with the fuel in the bowls but no tank on. Wheww hoooo !!Hoping that it had self corrected, I hooked the tank back up and it flooded again the same way.
