81 XS1100 special shifter
  • tonka1wlf
    • Jun 2007
    • 11
    • washington state
    Just got my bike back 2 mnths ago from my dad,cause i needed money,cleaned her all up an rode around locally an everything was working great,cept for decel backfire,witch i don't like.
    Changed oil an took off on a 460 mile run 2weeks ago and the last leg of the ride shifter had no tension? could shift up but only once down no more tension to bring shifter up to shift back down. Never had a shifter do this to me. ? Can i still ride safely untill i can find out what or how to fix? An is it true or not that i will have to pull motor to fix it?
  • dewibp
    • Jun 2005
    • 315
    • Work out of Dakota Dunes SD but live in eastern Iowa (Quad Cities)
    Do a search for shifter fork as I just read something about a spring that is suppose to bring the shifter lever back up. Sounds like it is either broke or somehow came lose. Not that bad of a job to remove the side cover to determine what repairs are needed. I've got some extra ones laying around if in deed this is your problem. In an emergency you could ride it but you will not be able to go very fast as you will over rev (in my opinion) the engine.
    DEW
    One Red "Creation 1"
    One Black"Creation 2"
    One Black"Creation 3"
    One ???? "Creation 4"
    One ???? "Creation 5"
    One ???? "Parts Bike"
    All the above 1100 Specials
    78 Standard (Ruf Ruf)
    1980 Midnight Special
    1978 650 SE
    • mitch
      • Oct 2002
      • 934
      hERES YOUR FIX
      CHECK THIS OUT
      http://www.xs11.com/forum/showthread...&threadid=2785 YES YOU CAN DRIVE IT YOU JUST HAVE TO SHIFT WITH OUT THE SPRING RETURNING IT TO CENTER
      DOUG
      Doug Mitchell
      82 XJ1100 sold
      2007 Stratoliner 1900 sold
      • dewibp
        • Jun 2005
        • 315
        Yup Mitch, thats the one!
        DEW
        1978 650 SE
        • mro
          • 4276
          • Hayward, California
          No need to pull engine to remove shift cover.
          May need drain oil and to drop exhaust that side to get to lower alen bolts. (I've managed to get it off without doing either but would have been easier)
          mro
          • dewibp
            • Jun 2005
            • 315
            Make sure you line up the marks on the teeth (clearly seen in the picture) or it won't shift at all when back together. Tough lesson to learn but I am much wiser now....
            DEW
            1978 650 SE
            • tonka1wlf
              • Jun 2007
              • 11
              • washington state
              Thanks alot for the feedback guys I,ll let you all know what i find an give report. Also thnks for pics, they really help
              • DeanR
                • Jan 2005
                • 1499
                • Finger Lakes NY
                I replaced that spring a few months ago, using Ken's pictures. Easy fix for missed downshifts.
                As usual, thanks Ken for the great pics!
                80 SG
                81 SH in parts
                99 ST1100
                91 ST1100
