Hey there, thanks to all those quick responses, and all the good lucks, i use them frequently
well this morning I got the gas tank off, disconnected and removed the carb assembly. after inspection of the bowls, i found very little debris or rust.. and with a little looking found no real obstructions... actually the carb bodies looked clean and relativly clear.
this had me wondering what the prob is.. so i pulled the fuel sensor and found a lovely rusty box .. the float arm was all rust covered too... seemed to work fine (i was getting accurate readings from the digi-gauge)
Now for the fun part.. I pulled the petcocks just to double check what chuckles the previous owner had done while "rebuilding" the petcocks. and the following are what I found!
</br>
right petcock</br>
</br>
</br>
</br>
Left petcock has the entire screen housing broken off!! </br>
</br>
well IMHO I need new petcocks.. what are your thoughts? Also, does anyone know good deals on petcocks, or used petcocks, and where to get them.. again good used and cheap are my hopes!
I have a friend with a digi-cam coming by my work tonight to get some pics of the carbs to get to you all... I'll post them asap to get your opinion.. I have tomorow off, so thats my big day to get work done..
Okay now the tank, with the petcock stalk broken off (possibly in the tank) and the fuel gauge sensor covered in a nice rust casing, i am thinking the tank might need that radiator seal treatment i read about in the tech-tips... what are your thoughts on this treatment. also If i have the radiator guy do it, is he just gonna dunk it? this would mean I would have to repaint it no? well, any and all feedback is welcome!
thanks again in advance!
</br>
right petcock</br>
</br>
</br>
</br>
</br>
But, as stated, rebuild the petcocks, and get the replacement filter towers, AND Inline filters! Do the tank sealing yourself, several tech tips and recent threads on "removing rust" from gastank, etc.. You can probably use the same chemical treatment to remove the rust from the tank to clean up the fuel sender float/arm!
