limited top end
  • mro
    • 4276
    • Hayward, California
    originally posted by skids
    I could put in some 155 mains, but I think that is about as big as they go.
    Heres a list of available main jets
    (not listed are some smaller sizes)
    Order No Size
    004-177 92.5
    004-178 95
    004-179 97.5
    004-180 100
    004-181 102.5
    004-182 105
    004-183 107.5
    004-184 110
    004-185 112.5
    004-186 115
    004-187 117.5
    004-188 120
    004-189 122.5
    004-190 125
    004-191 127.5
    004-192 130
    004-193 132.5
    Order No Size
    004-194 135
    004-195 137.5
    004-196 140
    004-197 142.5
    004-198 145
    004-199 147.5
    004-200 150
    004-201 152.5
    004-202 155
    004-203 157.5
    004-204 160
    004-205 162.5
    004-206 165
    004-207 167.5
    004-208 170
    004-209 172.5
    004-210 175
    Order No Size
    004-211 177.5
    004-212 180
    004-213 182.5
    004-214 185
    004-215 187.5
    004-216 190
    004-217 192.5
    004-218 195
    004-220 200
    004-222 205
    004-223 210
    004-350 220
    004-351 230
    004-352 240
    mro
      • 5062
      Wow! I must have been limited to what was offered on the on-line website.
      mro
      • mro
        • 4276
        Ran across list on SUDCO site when looking for info on my flat slides. There's so much on that site it's hard to find stuff
        mro
        • MAXIMAN
          • Jan 2005
          • 1817
          Skids
          Patrick is probably right. I think your mains are too big.
          But try this. Drop it into 4th and see where she'll top out then. Although the 750 drive helps reduce revs it doesn't reall help most Elevens up top because they don't have enough power to pull the taller gearing to redline in 5th with the taller rear end.
          I bet if you top it out in 4th you'll see a much higher top end.
          • xschop
            • Feb 2006
            • 1794
            • oklahoma city
            power
            he's at least got 12% less horsepower than normal due to his elevation if he's going off stock settings...for every 1000ft from sea level,you loose 3% of your horses.
            MDRNF
            79F.....Not Stock
