Well just finished adjusting the floats on my carbs with the exception of number four i set the levels on the floats at 25.7mm
hope this is okay waiting on new pilot jets rejetting carbs to match the 4 into 1 exhuast and the k&n filter moved the clip on te needle one notch installed 145 mains will be putting 45 pilot jets when then get here from mikes xs just have one problem i have one floats that sounds like it has water it i can shake it and it sounds like it does but nothing comes out how can i confrim this having trouble finding one float dont want to put a plastic one in it and the rest metal if one of the carb wizards can help please advice me
You'll want to put it in the sun for a few hours to heat it and help it evaporate out of it. Then like MRO said, put it in almost boiling water and check for bubbles which you will probably find. You can solder it, but has been suggested to put the float on a bed of ice to help keep the air from expanding too quickly while applying the hot solder which can blow the solder away from the float surface/hole!
