How do I determine what bearing I need?
  • Drichey
    • Jun 2007
    • 12
    • vassar michigan
    Main and rod bearings are listed in colors, how do I determine which color I need? someone said there is a number on the crank and a number on the case and I subtract the two. Is that true?how do I convert the number to a color? Will the dealer have any of this information?
    Thanks for your help
  • Wildkat
    XS Special Gurette
    • Apr 2004
    • 3416
    • Location, Location
    Here you go
    Please follow this link
    Look for John's post... he tells how to do it and what the conversion is for colors and numbers...
    81 SH Something Special
    79 SF MEAUQABEAUXS
    81SH Nor'eas tah (Old Red)
    80 LG Black Magic
    78 E Standard Practice
    James 3:17
    “Alis Volat Propriis”
    Yamaha XS 1100 Classic
    For those on FB
    • Drichey
      • Jun 2007
      • 12
      • vassar michigan
      Do I need 5 main bearings (1 set per journal)
      or 10 bearing halfs?
      • randy
        • Dec 2003
        • 4521
        Drichey,
        For a full set, you'll need 9 plain bearing halves and 1 thrust bearing half. Total 10 halves for the 5 mains The center main has the thrust bearing in the top half.
        Some of the thrust bearing colors are discontinued, but BikeBandit has most of the bearings available. Full set is about $140.00. When you find out the colors you need, PM me. I have a complete NOS bearing set and will give you a good deal on a full set.
