Ok so mine works on fours that have a distribrutor. Anyone have a trick to have the tach read twice the pulses. I have it working at half the correct RPM.
Our coils each spark once every RPM and the tach wants 2 pules/RPM
I think I will try two high value resistors. One tied to each neg. coil primary, then tie the two together and hook up the tach there. Wild guess value 100Kohms. The resistors need to be enough to trigger the tach but not the other coil
14vdc/200kohms=70microamps
"Just like Edison, I will attempt to proof something I know nothing about."
