Pilot Jet for 80 sg
  • mraaaaaaaaaa
    • Jan 2007
    • 49
    • cleveland, ohio
    Pilot Jet for 80 sg
    Need some info, picked up a decent carb for My 78e.
    Had to reverse drill out 2 of the pilot jets.
    Just received them, & noticed that on the body of them,
    their are NOT ANY drilled out holes.
    Checked Yamaha microfitch, and the part numbers are
    correct.
    Sooooooooooooooo, do I need the three holes, like the
    ones had that I took out, and also the other two had
    the holes also.
    Even MY 78e pilots had them with the holes !!
    I cannot see any difference in size or anything else different
    other than Not having the holes.
    So, whats up with them, Iam baffled.
    Thx in advance, & tc & keep the back rubber down !!
    Andy B. North Coast, Ohio
  • red bandit
    • 951
    • central michigan
    Yes you need the 3 holes.
    79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box w/larger velocity stacks, 750 FD.
    79 SF parts bike.
      • 5058
      Were like that from the factory, or do you know? I have heard others also make that claim.
      • mraaaaaaaaaa
        • Jan 2007
        • 49
        • cleveland, ohio
        pilot jets, cont.
        Probably not like that from the factory.
        Also, found out today that the guy that sold me the carb, checked
        the title, & finally gave me the # off of it,
        it is a 1981sh eleven special, LOL !!!
        Soooooooo, the 2 pilots that I ordered, are the right ones for the
        carb., now the only problem I have is, that I had to order 2 more
        from My dealer, cuz, the ones that were in the carbs., were the
        Wrong ONES, LOL.
        So, anyway, Gunna slap them on My 78e when I get the 2 other
        pilots.
        Gunna be interresting to see if there is any difference in the
        performance of mine, will let ya know.
        TC all, & keep da back rubber down, ltr, Andy B.
          Hey Andy,
          Take a look at This Thread, last page , it might help you understand what you are wanting to get and what you are looking at!?
          • pggg
            • 1609
            • NZ
            My stripped slingshot carbs have the same no-holes mikuni pilot fuel jets, the pilot air tube doesn't run through the pilot jets like on the xs carbs, the air pilot tube flows past the jets' nozzle instead, can't see them working very well in the XS carbs
              Hey Patrick,
              That brings up a good point regarding the statement that MikesXS makes about being able to use the no holes pilots vs. the holy ones....of course they are referring to the XS650 series of bikes and carbs. I don't have an exploded view of the fuel/air pathways for the 650 carbs, but being the same circa/year I wouldn't think that they(Yamaha) would have designed them much different than the XS11 carbs, and so I wonder IF their statement really is true about being able to use the NO HOLES type pilots in the 650 carbs??
              I just know that when I took my 81SH apart, it had the HOLY pilots, and I feel they are critical in providing the proper air mixing properties for the pilot jet circuit, and without them, it should make them run richer cause less air is being drawn into the circuit thereby sucking more fuel thru the jet and richening it up!?
