transmission shimming
  • rev79xs11
    • Aug 2004
    • 60
    • Harrisburg, PA
    Just received a good trans assy and am planning to swap it into my 79sf. While cleaning up and inspecting the gears I noticed countershaft 2nd gear has a good bit of side to side movement on the shaft with the washer and circlip in place. Is this normalto have around an 8th inch movement?
    Thanx!
    Ron Evans
    79 xs11sf
    99 kawasaki ninja 250 (70mpg)!
  • mro
    • 4276
    • Hayward, California
    I've had a few apart...
    Seems normal.
    Do check washer/clips are not worn as well rest of tranny.
    If you've already got it apart, would consider "under cutting" all the gears/dogs etc..
    Pretty sure that Maximum said that new factory gears are still available and come that way.
    Good description/pics in the tech section under "second gear fix".
    mro
