ENGINE: Back In the Frame
  • renniks73
    • Dec 2006
    • 18
    • Tulsa, OK
    Anyone with some tips on getting the engine mounting points lined up for the bolts? The engine is now back in the frame of my XS11 LG and we're wrestling with many of the mounting points.
    1. Which one do we start with?
    2. Is there one that seems to work best for reinstallation?
    Any insight would be greatly appreciated.
    Thanks.
  • 79XS11F
    • 3563
    • Ottawa, Ont. Canada
    I do it with a bottle jack. Just protect the oil pan by having a block of wood between the small head of the jack and the pan.
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
    • mro
      • 4276
      • Hayward, California
      Thing called a "drift pin".
      Like a large tapered punch,
      stick in a hole to align it or one next to it.
      Can sometimes use large round shaft screw driver.
      mro
      • desert1
        • 750
        • Grand Desert, Nova Scotia, Can.
        jostle
        Take your time with it and jostle it around with a jack or sissor jack like Rob mentioned' youll get it....get your rods and frame mounts doesnt matter what order...dont wrench anything tight until all the bolts are in place correctly....(Oh by the way Rob my timing was out 180 deg as well) I'm now on the road)
        Bruce
        Bruce Doucette
        Phone #1 902 827 3217
        • desert1
          • 750
          Rennicks 73
          Oh forgot to mention I just swapped motors in my 78 over the last couple months......the actual install was about 3 hrs
          Bruce Doucette
          • renniks73
            • Dec 2006
            • 18
            • Tulsa, OK
            Thanks for the advice and encouragement guys. I'll keep trying to fidget with it. As soon as I get it "in" I'll try posting a pic for everyone to check out.
            Thanks again!
            • desert1
              • 750
              Rubber boot
              Oh Rennicks forgot to mention this but pull back and tie-off as far as you can the rubber boot that goes around your universal drive joint....it can get torn by the coupling during install dont ask me how I know tighten your coupling bolts pretty tight as well as they say here on the south shore....." Come horny on to her!"
              Bruce
              Bruce Doucette
