Coil Question
  • jimboreeno
    • 427
    • Smithville, MO
    Coil Question
    Hi All,
    I have read several threads regarding poor performance when riding in the rain. The other day I got caught in a toad-strangler on the way home. The bike started running real rough. I limped home and discoverd that 1 and 4 header pipes were not hot. 2 and 3 were sizzling.
    I figure the coil must be shorting out.
    Before I pull it, is there a way to test the coils to see if they are functioning properly. I am pretty sure I will pull them and end up saying, "gee...looks alright to me!"
    OR...ant other ideas??
    JimBoReeno
    My Ex!"Half-Breed"
    '82 XJ1100 Maxim with
    '80 XS1100SG Motor
    Current Bike
    2000 Indian Chief
    Millennium Edition
    Read this thread
    and check the tech tips on coils
    • jimboreeno
      • 427
      • Smithville, MO
      yeah I read it just before I posted. My question is how to test a coil to see it it is working properly or not.
      JimBoReeno
      My Ex!"Half-Breed"
      '80 XS1100SG Motor
      Current Bike
      2000 Indian Chief
      Millennium Edition
      • 79XS11F
        • 3563
        • Ottawa, Ont. Canada
        Make sure the connection between the plug wire and the plug boots is GOOD and then between the boot and the plug . Use dielectric grease at these locations to keep moisture and corrosion out of the connections. I do this at EVERY connection in the electrical system including grounds. i got caught in a rain storm once last year and did the 2 hour drive home in the rain and my bike didn't miss a beat ... not once.
        Rob
        KEEP THE RUBBER SIDE DOWN
        1978 XS1100E Modified
        1978 XS500E
        1979 XS1100F Restored
        1981 Suzuki GS1100
        1983 Suzuki GS750S Katana
        1983 Honda CB900 Custom
        • 79XS11F
          • 3563
          The coils themselves are almost indestructible ... it's the wires that is a weak link. Check your manual for the procedure and expected / normal readings.
          Rob
          1978 XS500E
          1981 Suzuki GS1100
            Did you read this one
            Jimbo,
            Read this tech tip....you will need a voltmeter to do the test.
            • jimboreeno
              • 427
              • Smithville, MO
              Turns out one of the coils has a large crack in it and the readings are way off.
              I found THESE at JC Whitney. Any reason they won't work?
              I talked to a rep who said they would work fine.
              JimBoReeno
              My Ex!"Half-Breed"
              '80 XS1100SG Motor
              Current Bike
              2000 Indian Chief
              Millennium Edition
              • jimboreeno
                • 427
                • Smithville, MO
                Of course now I see they say "not for 4 cyl"
                JimBoReeno
                My Ex!"Half-Breed"
                '80 XS1100SG Motor
                Current Bike
                2000 Indian Chief
                Millennium Edition
                  Hey Jim,
                  Have you not been paying attention lately?? I posted a tech tip about using the MikesXS coils on our machines, work very well, are 35Kvolt strong, and don't require the ballast resistor. If you've got one bad coil, might as well to replace both, that way no problem with the ballast resistor bypass!
                  MikesXS Coils UPgrade tech tip.
                  • jimboreeno
                    • 427
                    • Smithville, MO
                    OF COURSE I have not been paying attention....What Kind of Question is THAT?!?!
                    Thanks TC. I did the 'ole post first, search later
                    I actually found a replacement set on FleaBay. They appear in good shape and weren't too expensive. I hope I don't wish I had upgraded with the new, but we'll see!
                    At least I'll be back on the road and HOPEFULLY able to ride when wet!
                    JimBoReeno
                    My Ex!"Half-Breed"
                    '80 XS1100SG Motor
                    Current Bike
                    2000 Indian Chief
                    Millennium Edition
