starter clutch
  • procamper
    • Aug 2002
    • 68
    • slinger wi
    starter clutch
    Anyone ever have problems with the stater clutch not engageing when trying to start? For the last couple days its been acting up. Somtimes it works right away but other times it just takes a couple tries to get it to work.
    Maybe it has to do with the cold weather making the oil thicker
    yet another item to add to the winter to-do/check list...
    79ish suzuki rm250
    82 honda cb450sc
    78 honda cx500
    72 honda cb175
    78 yamaha xs11e
    Re: starter clutch
    You hit the nail on the head: Cold temps, thicker oil, and/or full synthetic oil can all contrute to the starter slippage. It sounds nasty but causes no damage that I I am aware of. Either change oil to lessen the affects or just shine it on!
    • procamper
      • Aug 2002
      • 68
      • slinger wi
      Thats what I had figured. just changed from 20w-50 to 10w-40 for this winter, was hoping that would solve it, but only helped.
      anyways, now i have to figure out why my turnsignals stopped working... always somthing, but thats why old bikes are fun, right?
      79ish suzuki rm250
      82 honda cb450sc
      78 honda cx500
      72 honda cb175
      78 yamaha xs11e
      • uk1.1s
        • Oct 2002
        • 365
        • Surrey UK
        Turn signals
        Think my turn signals (or indicators in UK-English ) packed up when the auto-cancel unit gave up the ghost.
        Years ago when this first happened I replaced it (at whatever rip-off cost the shop wanted back then). Less than a year later, same thing happened - the unit fails and the indicators stopped working.
        Of course if you dissconnect this little black box the lights wink fine - but you have to remember to cancel them by hand - no big hassle really unless you are HUGELY lazy!!
        If you've got the same problem - the unit on my bike is in a rubber cover, fitted to a bracket on the frame, just in front of the forward fixing for the left hand side panel. Have a look, pull the plug apart and you may have the lights back.
        XS1.1 sport - Sold June 2005 :-(
        Guzzi 850
        Z1000
        • sixtysix
          No XS but XSive as can be!
          • 1958
          • Central New York State
          Re: Turn signals
          Don't you mean directionals? Or Winkers? Blinkers? What kind of English is that!! We just had this discussion on the Triumph list a few moths ago. I think a poll is in order....look for it in a few minutes!!
          Gary Granger
          • xsivebiker
            • 219
            • Summersville,W.V. U.S.A.
            Re: Starter Clutch
            You can use the old ATV owner's trick: borrow the better half's blow dryer and warm up the sides of the starter housing first. I've used it on my '80-G one very cold morning and it works.
            1980 XS1100-G
            1982 CX500 Custom
            1979 XL250-S
            • chopper
              • Nov 2002
              • 167
              • scotland
              starter clutch
              if you have to replace it........ $18 at www.partsnmore.com
              mick
              xs1.1s(x2)
              gsxr1100(1127)
              gsx1100g(x2)
              trophy900
              bonneville750
              http://www.tonyfoale.com/
