wiring harness and ignition switch socket problem
  • midnight1980
    • Mar 2007
    • 312
    • cedar city, utah
    well i finally found the right wiring harness but as you can see the sockets are totally different for the ignition switch wiring?
  • Brian_D
    • 355
    • Gardner, KS
    aftermarket ignition switch?
    can't quite tell by the photo but appears that connector on switch is a 6-position connector
    also appears that same connector has not discolored or weathered enough to be oe.
    78-79 uses a 3-position connector with Brown, Red, and Black
    80-81 uses a 4-position connector with Brown, Red, Black, and Blue.
    • midnight1980
      • Mar 2007
      • 312
      • cedar city, utah
      Re: aftermarket ignition switch?
      no its a 4 connection both are but the one on the wiring harness is a smaller socket then the the ignition switch socket?
      • midnight1980
        • Mar 2007
        • 312
        • cedar city, utah
        i found a small socket its for a 1979 special
        • Brian_D
          • 355
          • Gardner, KS
          79 ignition switch
          won't work on the 80 harness. 78-79 have a 3-position connector for the ignition switch AND the harness.
          • Brian_D
            • 355
            • Gardner, KS
            you sure the connector on the ignition switch only has 4-positions? or is it a 6-position connector with only 4-pins?
            • midnight1980
              • Mar 2007
              • 312
              • cedar city, utah
              Re: 79 ignition switch
              ok i took this photo of a connector from the wiring harness is this the 3 pin your talking about
              • Geezer
                • May 2003
                • 2985
                • Willamina, Oregon 97229
                I stock both the larger 3 and 4 prong plugs. Let me know if you want to replace just one side of either of these.
                Geezer
                • Brian_D
                  • 355
                  • Gardner, KS
                  BLUE NOT BLACK
                  that is exactly what the 78-79 ignition switch connector looks like ON THE SWITCH SIDE....the harness side connector is female. both connectors will have one RED, one BROWN, and one BLUE wire. (in my earlier post I mistakenly referred to a black wire - there is no black wire in the ignition switch)
                  the 80-81 ignition switch connector is a 4-pin/position male on the switch side and 4-pin/position female on the harness side. it also has one RED, one BROWN, and one BLUE wire, the additional pin is used for the hazzard lights....don't have access at the moment to tell you the correct color of the additional wire.
                  • midnight1980
                    • Mar 2007
                    • 312
                    • cedar city, utah
                    Re: BLUE NOT BLACK
                    what your looking at is the harness its a male socket ? 3 plug so i will have to find a
                    79-78 ignition switch and solder the wires together then.
                    • Brian_D
                      • 355
                      • Gardner, KS
                      before rewiring, use a volt meter and check the connector on the harness side - RED should be direct battery feed thru the 30A main fuse - hot all the time. BROWN will connect to the OFF-RUN switch thru the ignition fuse. BLUE supplies power to the lights.
