Hey,
Due to medical reasons I can not balance my 1980 XS 1100MNS, so I am in the process of making it into a trike as follows. I have taken a 1980 xs850 back wheel and cut out the hub with the drive clutch.I have an adpater plate that I will bolt to the drive clutch and also to a 42-tooth sprocket. I have taken off the rear shocks and have replaced them with solid struts, I will make the rear axle into a jack shaft that will chain drive a one inch live axle immediately behind the rear axle but far enough back so that I can fit a sprocket on the live axle and connect it with a 41 chain. I am in the process of preparing the frame extension which will be bolted to the existing frame so that I can bring it back to two wheels if need be in the future. The live axle is 48 inches long and it will drive two 14 inch wheels with 4 mounting holes. I am adding two rotors to the live axle that are replacing the single rear disc brake. Will my madness work or do you think that I may experience a lot of rear wheel hop with the solid suspension???
Marc
Marc
