well deceided to give carbs a good cleaning this time and its a good thing i did too found out po used teflon tape on the fuel fittings between the carbs and the ones feeding 2 and 3 were partially blocked off so im thinking that 1 and 4 were getting a god fuel supply while the other two werent and the vent tubes had some gunk in them working on them just about clean only reason i can think of why po used teflon tape was because they were leaking if there still available i will replace them im not going to let the carb thing get the best of me
