tachometer
    • 2072
    tachometer
    I found several sources for a tachometer thanks to the internet.Will a 1979 work with an 1980.Will everything plug in?
  • webbcraft2150
    • Sep 2002
    • 1605
    • AUSTIN.TX
    We kinda need to know which model you are workin on. Special (puny gas tank) or a standard (camel like gas tank).
    • webbcraft2150
      • Sep 2002
      • 1605
      • AUSTIN.TX
      Sorry, didnt read the name. SG means ya have a "Special" (round tach/speedo. Should be a bolt on, plug in, and run. I just happen to have a full set of "special" gauges sitten in my box-o-parts. Go figure, I ride a standard. Are ya lookin for a set?
      • Lamric
        XStremely XSive(Deceased)
        • 410
        • Kenley, Surrey, England
        Ditto. What the man says.
        The 1980 SG model has the same tacho as the 1979 SF model, part number 3H3-83540-01-00.
        Brian
        XS1100 LG "Mr T", SG "ICBM" & FJ1200
        Check out the XS Part Number Finder
        Be not stingy in what costs nothing as courtesy, counsel and countenance.
