WELL FINALLY GOT MY PILOT JET THANKS FOR THE INFO ON THE LEFT HANDED DRILL BET WORKED OK STILL HAD TO USE A SMALL PAIR OF NEEDLE NOSE PLIERS TO UNSCREW IT WITH USED ONE SIDE OF THE PLIERS GAVE IT A LITTLE TAP AND THE UNSCREWED IT THAT MADE ME HAPPY WAS READY TO CLEAN THEM PULLED THE AIR MIXTURE SCREWS OUT SO I COULD GET TO THE LITTLE O RINGS AND WASHERS OUT SO I WOULDNT LOSE THEM AND GUESS WHAT ? NO ORINGS AND NO WASHERS AUGGGHHHH WHAT NEXT SO I TOOK A LOOK AT THE FLOATS THEY LOOKED OK SO I GAVE THEM A LITTLE SHAKE TO SEE IF ANY HAD FUEL IN THEM AND SURE AS S@#$ #3 HAD A SMALL AMOUNT OF FUEL IN IT WHAT ELSE CAN GO WRONG DONT NOBODY ANSWER THAT LOL SO NOW I HAVE THE FOOLOWING MISSING/BAD IN THE CARBS
1) BALLPOINT PEN SPRING USED FOR THE NEEDLE SPRING
2)ALL FOUR WASHERS THAT SET ON TOP OF NEEDLE CLIPS ON THE CARBS ARE GONE
3) FOUND ONE BAD FLOAT
4)AND ONE BROKE PILOT JET
NOW I ASK YOU SOUNDS TO ME THAT I GUESS I AM NOT MENT TO DO ANY RIDING THIS SUMMER I HAVENT MADE THE RIDING GODS MAD OR ANYTHING LIKE THAT WELL ANY HOW GUESS IM DONE VENTING GUESS I WILL STEP DOWN OFF MY SOAP BOX AND GO AND HUNT SOME PARTS UP
