proper float height
  • hoffman1
    • Mar 2007
    • 16
    • fairless hills,pa
    proper float height
    what is the proper float height and what is the best way to adjust them.
  • Ljay40
    • Jun 2006
    • 149
    Welcome hoffman
    The best way to adjust them is to bend the tang up or down which ever way you need to go
    Have you check out the Tech Tips on the main Forum Page
    scrool down and you will find a ton of information and if thats not
    enuff for you go the top of your page and in the search section type in floats or carbs or whatever your interested in and you will recieve tons of info
    My 80 special floats according to the manual are 23mm
    lots of guys vary there floats tho to richen or lean there bikes
    so its kinda Users choice what ever works best for you
    hope this helps a bit
      Welcome,
      The float height depends on the year of the bike, and the intake and exhaust system on the bike. I run my '79 at about 27mm, but 1mm off will make a BIG difference.
      As Ljay40 said, scroll through the "Tech Tips", but get there from the MAIN forum page. click on the XS11.com link at the top of the page, and THEN go to the "Tech Tips".
      • mro
        • 4276
        • Hayward, California
        82 XJ ???
        Later carbs, 80/81 float height 23mm +, - .05mm
        carbs upside down measured from bowl gasket surface to highest point both sides of float.
        (yammaha manual)
        XJ carbs I've not got the chance to mess with so....
        good luck
        mro
        btw,
        YICKS tool tip may be something you want to check out
