Dyna Coils
  • opajim
    • May 2007
    • 16
    • Mena, AR
    Dyna Coils
    Recently I bought Dyna Coils on eBay. They are supposed to measure 3.0 ohms between the primary wires but these consistently read 3.4 ohms, checked the same on three different multimeters. I would like to use these coils, but before I invest in wires, caps, etc., if this is the true resistance, is there any danger of damaging/destroying other components,
    TCI for example?
    Thanks,
    XJ100J
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    coils
    I used dyna coils with accell wires straight to the plugs with no resistors on my 79f... I haven't had ANY problems in 3 yrs since the swap.... I know that there is a ballast resistor on some models that affects the type of coils you have to use.....
    MDRNF
    79F.....Not Stock
      Hey Jim,
      The stock resistance for the XJ was like you said around 3 ohms. A little more will not hurt anything! What would hurt would be if you had gotten the coils that were for a true CDI system, that are only 0.7ohms, then it would draw way too much current.
      • opajim
        • May 2007
        • 16
        • Mena, AR
        Dyna Coils
        Thanks, that's the info I needed. Now for
        wires and plug caps. Any advice on that
        subject?
        Thanks,
          I would look for the GOOD racing wires. they are NOT cheap, but are wire wound, and with the matching caps, should work fine.
          • Pat Kelly
            • 3046
            • Golden Valley, AZ
            I used the silicone wires from Dyna on my Dyna Coils. I didn't like the plug boots so I got MSD boots.
            Been working fine for 4 years now (been that long!?!?!?).
            Here's the link to my write-up
            Pat Kelly
            <p-lkelly@sbcglobal.net>
            1978 XS1100E (The Force)
            1980 XS1100LG (The Dark Side)
            1999 Suburban (The Ship)
            1994 Dodge Spirit (Son #1)
            1968 F100 (Valentine)
            • xschop
              • Feb 2006
              • 1794
              • oklahoma city
              dido
              that's the old link that I used to put mine on.the power increase is way noticeable. cold starts are also much easier...no resistor boots either.....who cares if the car next to you has their cell phone/radio damaged....
              MDRNF
              79F.....Not Stock
              • TADracer
                • 1417
                • Kenner, Louisiana USA
                I have been running Dyna 3.0 ohm coils with Accel 8.8MM Stainless wires for a few years now. They put out 35,000 volts and wires make sure all of it gets to the plugs. Like chop says, the difference is noticeable.
                Mike Giroir
                79 XS-1100 Special
                • Pat Kelly
                  • 3046
                  • Golden Valley, AZ
                  As you can see in the 1st pic on my tech-tip I have the 1.5 ohm and I kept the ballast resistor.
                  Pat Kelly
