Front Brake Master Assy snap ring issue
  • davestrike
    • Mar 2007
    • 94
    • Tacoma, WA
    Ok All,
    I finally got the tool to remove the front brake master cylinder to repair it. Started to poke around and scraped the rust away to see inside there, and guess freaking what! The snap ring has no holes!
    The snap ring appears to be missing the two little holes to apply the snap ring tool ends into.
    Any ideas on how to fix this? Or is it time for a new Master Assembly?
    I did find a possible replacement at Parts N More.
    DUAL DISC MASTER CYLINDER
    Dual Disc Master Cylinder Assembly. Yamaha Style - Alloy body Master Cylinder Assembly with Lever, Banjo Bolt, Banjo Bolt Washers and Brake Switch. High Quality , Low Profile Design featuring 16mm cylinder with 10 x 1.25 threaded outlet. Fits 7/8 inch Handlebars, Accepts Yamaha Style Left Hand Thread, Right Side Mirror.
    $76.00US EA. Part#08-0264
    Thanks in advance.
    Dave
    Dave
    Tacoma, WA.
    The new M/C will be your best bet, especially if the holes in the snap ring have rusted away. A long soaking in WD 40 or similiar product may loosen it up enough where you can get a small dental type pick in there and dig it out. If you can keep the piston compressed, maybe you can loosen it up with the pick or small screwdriver, and dig it out from the bottom side of the snap ring.
      • 1897
      By a kit
      Dave,
      If you can get the remains out I am sure you can get a rebuild kit from Bikebandit. The rebuild kit is about 43.00.
        The ring will have the obligatory two holes. Chances are there is just so much rust and cr@p in there that you just can't see them. Use a dental pick or some other fine point device to scrape around where the holes would be. I'm sure you will find them.
        • Pat Kelly
          • 3046
          • Golden Valley, AZ
          That parts n more master cylinder works. I have it on both my XS's.
          Pat Kelly
          <p-lkelly@sbcglobal.net>
          1978 XS1100E (The Force)
          1980 XS1100LG (The Dark Side)
          1999 Suburban (The Ship)
          1994 Dodge Spirit (Son #1)
          1968 F100 (Valentine)
          • davestrike
            • Mar 2007
            • 94
            • Tacoma, WA
            Thanks All for the suggestions!
            Unfortantely, the holes are gone. I used WD40 to clean it up some inside and nada.
            So PartsNMore gets some of my money.
            If I want to ride this beastie down to Oly in August, I kinda need front brakes.
            Dave
            Dave
            Tacoma, WA.
            • Pat Kelly
              • 3046
              • Golden Valley, AZ
              Only if you want to stop when you get there
              Pat Kelly
                • 1897
                Does the back brake work
                Although I would not advise it I have read that some folks on this forum have actually ridden with just the back brakes working.
                • davestrike
                  • Mar 2007
                  • 94
                  • Tacoma, WA
                  Very true Pat!
                  Dave
                  Tacoma, WA.
                  • 79XS11F
                    • 3563
                    • Ottawa, Ont. Canada
                    That's a lot of rust to dissolve the clip holes away. Was the rubber boot in place or badly damaged? It would be very difficult to remove that clip without damaging the walls of the bore with out the compression holes.
                    Rob
                    KEEP THE RUBBER SIDE DOWN
                    1978 XS1100E Modified
                    1978 XS500E
                    1979 XS1100F Restored
                    1981 Suzuki GS1100
                    1983 Suzuki GS750S Katana
                    1983 Honda CB900 Custom
                    • davestrike
                      • Mar 2007
                      • 94
                      • Tacoma, WA
                      79X,
                      The rubber boot is still in place and in pretty good shape. It appears that someone attempted to remove the clip before and that is when the very rusted holes broke.
                      Like I said, Parts N More now has $76.00 of my money for a replacement. No way am I screwing around with bad brakes!!
                      Dave
                      Dave
                      Tacoma, WA.
                        It's a moot point but - - -
                        Hi Dave,
                        I'd suppose that if the snap-ring extractor lugs had rusted all away the rest of the m/c would be rusted solid too? Perhaps it's more likely the dreaded PO lost the original and replaced it with an earless one. They slide in OK, it's getting them out again that's hard.
                        Now that you have a replacement and if you care to experiment, try grinding through the snap-ring with a small tungsten carbide or abrasive ball on a Dremel tool and see if you can't pick out the two halves. Yes there will be a pit left in the bore but you only need a good bore surface further in where the seals are.
                        You may even end up with a usable spare.
                        Fred Hill, S'toon.
