throttle lock
  • dodjh
    • Nov 2006
    • 124
    • Buck Snort, Mississippi
    throttle lock
    Is there a universal throttle lock or does it have to be one specifically for your bike?
    dodjh
    Semper Fidelis to my brothers serving on foreign hostile soil
    Throttle locks are for 7/8" or 1" handle bars. They will fir almost any bike, so yes, they are "universal".
    • Jerry
      XS & TRUE XJ GURU
      • 3023
      • Elma, IA.
      Some bikes (Honda comes to mind) use a 2-cable system for the throttle. Yamaha uses 1 cable. If you are looking for a throttle lock try to find the single-cable unit, slightly easier to fit and looks better. Twin-cable will work, but you have 2 sets of 'fingers' that go around the base of the throttle cables, one set won't be used.
      Jerry Fields
      '82 XJ 'Sojourn'
      '06 Concours
      My Galleries Page.
      My Blog Page.
      • Dennyz
        • 1151
        • Olympia, Washington
        This type has worked well for me,
        DZ
        Vyger, 'F'
        "The Special", 'SF'
        '08 FJR1300
        • dodjh
          • Nov 2006
          • 124
          throttle lock
          I had never seen or heard of one until I was reading through some past posts in this forum.
          The picture of the type Dennyz has, stopped my imagination process of what one would look like.
          Thanks for the replys,
          dodjh
          • mro
            • 4276
            • Hayward, California
            Can look like this too
            Mine needs a little tinkering as it likes to slowly let the throttle slip
            mro
            • DeanR
              • Jan 2005
              • 1499
              • Finger Lakes NY
              Denny..... Just put one of those on my bike for a pretty long trip this summer. I've noticed a couple things that I'm wondering if you had problems with.
              First, and it's not a big deal, is that the lever winds up being positioned right in front of the starter button. Kind of a pain.
              Second, and of more concern, is I can't seem to get it adjusted so the throttle snaps right back like it should. I moved the grip back a little to make sure that wasn't binding and it still is not quite free. The tension is adjusted just barely tight enough to maintain set speed. What's been your experience?
              80 SG
              81 SH in parts
              99 ST1100
              91 ST1100
                NEPs make a throttle lock that works pretty good, but the handle snaps onto the pivot point and can come loose.
                • Dennyz
                  • 1151
                  laxdad:
                  I solved this problem by rotating the throttle housing forward a bit.
                  It took me a while to get this right. I had to trim the rubber grip a bit and my throttle still does not snap back with the engine off. It returns, but not a snap. With the engine running, it snaps back fine.
                  I run mine adjusted just tight enough to hold position.
                  Good luck
                  DZ
                  Vyger, 'F'
                  "The Special", 'SF'
                  '08 FJR1300
                    Anyone know the cheapest place for a universal throttle lock that looks like Dennyz's in the picture? I see them for about $35. Seems a bit steep to me for such a small amount of hardware.
                      Just found one at JC Whitney for $25. Is this the cheapest one?
                      • renegade_xs11g
                        • 462
                        • Mid-Michigan
                        Gentlemen...If anyone is interested...
                        I have access to a couple of the throttle locks like MRO's
                        Used, but useable....
                        If interested...PM me
                        My Photo Bucket
                        • DeanR
                          • Jan 2005
                          • 1499
                          • Finger Lakes NY
                          Just got back from my trip and the vista cruise did work pretty well. The lever does however, frequently interfere with starting regardless of where I position it.
                          80 SG
                          81 SH in parts
                          99 ST1100
                          91 ST1100
