Hi all,
I am getting ready to reassemble my motor as well as the rest of the bike after a winter complete strip down.
I had a leak at the back on the base gasket and took the motor down to replace it. As it turns out when I took it apart I found a broken top ring on #1 cylinder, no damage just broken in two pieces.
Anyway my question is:- when putting the base gasket on do you add anything to help it seal or does it just go on dry?
I have cleaned both surfaces with laquor thinner and made sure there are no nicks or scratches in the surfaces. Also got all the grit (I'm hoping) that fell into the crankcase from the cylinder lift with a small tube and a vacuum.
Thanks
Ed
Thanks
Ed
for this one
then I was talking to a machinist at work who works on bikes quite a bit and he told me about the gear clamp trick.
