Carb help for the new guy
  • gmlever
    • Mar 2007
    • 22
    • Iowa
    I need some opinions to see if I'm doing this right ?
    I have a 1980 XS1100sg, only had the bike a few months.
    When I got it the air box was drilled,I put a K&N air filter in it and it has a Kerker 4into1 header.The bike was running rough between 1000 and 3000rpms so I took the carbs off and cleaned them (had the usual problems thanks to this web site got everything fixed) My question is jetting it had 110 mains all across and I think 42.5 pilots ? So I bought 115 mains and 45 pilots.My main concern is the 45 pilots has anyone used this combination ? Anybody think it will work or not ? Any better suggestions ? Also floats are at 23mm..Waiting for one intake clamp from bikebandit to install the carbs.
    Thanks for any help
    What a great Web site !
    Gmlever
    80 XS1100SG
    Tkat fork brace,Progressive suspension,
    E3 tires,Iridium plugs,Mikes black coils,Standard handlebars,Kerker header.
    Ankeny,Iowa
    You should be OK with the jets. You may have been able to just turn the idle mixture out an extra turn or two. I would start the mixture screws out 1 1/4 turn on all 4, and tune from there.
