Paint: how to polish base coat prior to clear
  • Shuriken
    • 1093
    • Southwest USA
    Hi everyone,
    On Friday night, I painted my tank and side panels jet black with paint from www.paintforcars.com . It is acrylic paint. I am very happy with the results. The paint is not expensive and goes on very well, dries quickly, and it leaves a fantastic gloss.
    It was windy in so. Utah (of course) and I have some things that found their way onto the surface of the base coat. What's the best way to take care of this issue?
    Basically, if I were to polish/buff the base coat prior to spraying the clear coat, I think the little fibers and dust would be eliminated.
    I've never buffed/polished/sanded a base coat prior to applying the clear coat because I've had such good results with the base coat.
    Do you guys recommend wet sanding the base coat and if so, with what kind of paper? (1000, 2000, etc.) I want to keep that high gloss underneath the clear coat.
    Ben
    1985 Yamaha VMX12n "Max X" - Stock
    Formerly:
    1982 XS650
    1980 XS1100g
    1979 XS1100sf
    1978 XS1100e donor
  • underdog57
    • Jul 2006
    • 321
    • Alburgh , Vermont,054
    a good paint website
    I would try sanding it then re-base coat . Not sure whats reccomended , but the clear will flatten out if you wet sand it too.
    What does your paint supplier/manufacturer say ??
    But these guys are pretty sharp on painting...
    Articles, Features, Q&A, and How Tos for the automotive restoration enthusiast.
    Also take a look at this metal shaping site ...
    Bob
    1979 XS1100 SPECIAL (under 18,000 miles Sold 5/12/2016
    1982 XJ1100 MAXIM(PARTS BIKE??)shows 14,000 miles ??? Up for sale whole or parts
    • Dennyz
      • 1151
      • Olympia, Washington
      If the base coat is meant to have a clear put over it, you don't want to buff it. It needs to maintain "tooth" so the clear will bond.
      I would wet sand it with 600 to remove the bumps. Use a sanding pad. If you go through the base, shoot another coat of base.
      Put a few of coats of clear over it, wet sanding with 2000 between each coat.
      Then buff the final clear coat.
      That's my $.02
      DZ
      Vyger, 'F'
      "The Special", 'SF'
      '08 FJR1300
      • frogdink
        • Feb 2007
        • 146
        • Richmond, Maine
        ....help...
        i have a repair manual here at napa that goes over all the solutions to all the possible problems. the book says sand with 1200 or finer grit sandpaper and then compound polish to restore gloss. but that is for the clear coat. i would say just get a small strip of 1200 grit and hold it down on the spot you need to fix apply pressure and pull towards yourself. it should get rid of all the spots, and then just apply a mist coat ofver the whole thing. check the paint companys sheet though, you may need to scuff the whole tank lightly to get the new coat to stick.
        1982 XJ1100J
        Sold:
        1974 RD200
        1975 xs500
        1985 Honda XR350
        • Shuriken
          • 1093
          • Southwest USA
          Thanks for the help and replies.
          The salesman said over the phone to wet sand the base coat using 1200.
          I think I'll try some kind of cloth, first, and then see what's left on the surface of the paint. I really want to avoid sanding unless I have to, but I think it's recommended so the clear will stick.
          On the other hand, if I really have to, I could just spray on another coat of black and try to get luckier in the drying process. Hard for an amateur, without a paint booth, to get dust free.
          You guys should check out their paint line, though. I'm impressed so far.
          Ben
          Formerly:
          1982 XS650
          1980 XS1100g
          1979 XS1100sf
          1978 XS1100e donor
          • 79XS11F
            • Jul 2006
            • 3563
            • Ottawa, Ont. Canada
            I'm with Dennyz on this one. I have been told that as long as your happy with the evenness and number of coats of color you just apply the clear coat to that. Myself I would use a buff-able clear coat that has been built up in many layers. A buff-able clear coat will allow you to get a real deep appearance and no worries about over spray during the application.
            Rob
            KEEP THE RUBBER SIDE DOWN
            1978 XS1100E Modified
            1978 XS500E
            1979 XS1100F Restored
            1981 Suzuki GS1100
            1983 Suzuki GS750S Katana
            1983 Honda CB900 Custom
              • 1811
              If you sand
              If you sand it, definitely spray more base coat. Those sand marks show up throught the clear coat. Don't ask me how I know.
                Wet sand your base with 1200...........shoot again, let it 'flash' dry, and while still not completely dry, shoot again. After dry, wet sand, don't polish, shoot clear, wet sand, shoot again..and again after 'flash dry'......................wet sand clear with 1200 and then CAREFULLY power buff.................
                  Build a paint booth
                  if airborn crud settles on the wet paint you can either live with a lumpy paint job or wetsand the crud off and fizz on another coat. And if you are painting outside there's no guarantee the next coat won't get crudded too. Build yourself a temporary paint booth. 2x2s for a frame with builder's plastic stapled over it. Blow air in with an old vacuum cleaner and fer chrissake wear a good breathing mask, those paint solvents are seriously bad for your health.
                  Fred Hill, S'toon.
                  • Shuriken
                    • 1093
                    • Southwest USA
                    These are excellent responses. Thanks for the help. I will update with results.
                    Ben
                    Formerly:
                    1982 XS650
                    1980 XS1100g
                    1979 XS1100sf
                    1978 XS1100e donor
                    • Shuriken
                      • 1093
                      • Southwest USA
                      I re-sanded the base coat and sprayed a new coat of black a second time. This time, I got good weather. I just clear coated today and will update when everything dries.
                      Formerly:
                      1982 XS650
                      1980 XS1100g
                      1979 XS1100sf
                      1978 XS1100e donor
                        • 5051
                        pictures, Ben. We want pictures.
                        • Shuriken
                          • 1093
                          • Southwest USA
                          The artifacts on the paint are dust or fingerprints. These pictures are prior to washing or waxing. The paper towell is just to protect the paint.
                          Remember, this is urethane clear over acrylic, which worked for me.
                          Ben
                          Formerly:
                          1982 XS650
                          1980 XS1100g
                          1979 XS1100sf
                          1978 XS1100e donor
                            Nice job
                            Hi Ben,
                            those parts do shine like an outhouse door on a frosty morning. A really good looking finish. For being applied outdoors,
                            an effin' miraculous one.
                            Fred Hill, S'toon.
                            • Shuriken
                              • 1093
                              • Southwest USA
                              Thanks. I'm trying to get better and to use better tools each time.
                              Ben
                              Formerly:
                              1982 XS650
                              1980 XS1100g
                              1979 XS1100sf
                              1978 XS1100e donor
