valve timeing need help
  • brownbear1000
    • May 2007
    • 83
    • Bay View wisconsin
    I am trying to get my xs 11 running put new rings in it when i tryed to start it all i get is a ball of fire out of the # 2 carb jest got the bicke it was froze up from sitting the last 18 years in a shed took it all apart repard and cleand it up but now it will not start
    • 1987
    More information
    You will need to post everything you have done to the bike. You also need to tell everyone what you have.
      Was your timing on the crank on the "T" and the cams aligned to the dots when you installed them back in? If it is in time, it sounds like a valve isn't closing all the way for some reason. Check your valve clearances. Hopefully it was all in time so you didn't bend anything.
        Also might have put the wrong plug wires on the wrong plugs, firing during intake instead of compression stroke?? But, yes, we need lots more info about what all you have done to rebuild it!!
        Don't worry about how long the post/reply will be!
        • brownbear1000
          • May 2007
          • 83
          help
          the cams where on the marks and #1 was at T D C and i put the lifters all back in the same place and re seted the valves
          • brownbear1000
            • May 2007
            • 83
            xs11 special I put new rings in it cleand the carbs did not take the ING timeing a part the bicke sat 18 years put new gas lines on it polished the valves with fine valve grind compond put thepush caps and valve disks all back in the same place put the cams on there marks ant #1 at TDC. the T mark but all i get is the #2 carb back fireing <a big ball of fire >
              Well,
              Hate to tell you this, but the carbs can be a real "BEAR"!
              You stated you cleaned the carbs, but what all did you do to do this? Did you pull them down completely, or did you just take the float bowls off? Did you soak them in cleaner( a NO NO!)
              Have you done a compression test? Did you check the valve clearances once you got it all back together? Did you clean out the gastank? Does it still have the Octopus valve? Did you verify that fuel flows from the petcocks, and thru the octopus?
              Vacuum leaks can occur in many places, the old intake boots and their connection to the head, vacuum lines. What YEAR is this special? There are considerable differences in the carbs between the 78-79 series and the 80-81 series!
              There's also a great troubleshooting guide for the TCI in the links section, Randy's Home Page(resident Electrical Guru)!
              Do you have a multimeter? Several tests that can be done on the main igntion coils, spark plug wires, caps!
              • brownbear1000
                • May 2007
                • 83
                jest clean out the bols and made shour yvery thing mover only one carb was real bad did not tuch the settings
                will check valve clearance the carb boots are okand when i turn on the gass there is gasin all lines put new lines on it thay are clear lines so i can see the gas and i cleand out the gas tankgas comes out all the pedcocksthe old lines where as hard as a rock and going to recheck valve timeing too hope i can get it going
                have a lot of time and money in it
                • brownbear1000
                  • May 2007
                  • 83
                  its a 1979 eng. family 2H7-79
                    Well, Bear,
                    Hate to be the "bear"er of bad news, but you will probably need to pull the carbs again, and this time do a proper cleaning, removing the floats, the main and pilot jets, the main nozzle that comes up thru the carb body, the pilot screws, and then with several cans of carb cleaner, spray thru all of those holes to make sure you get spray out thru the 3 little holes in the front top of the carb throat, along with every where else. Don't forget EYE PROTECTION.
                    Don't soak the carb bodies!! Inspect the float bowls, there's a jet in it, make sure it's open, use a small soft piece of wire if needed along with carb cleaner to get it open and flowing..that's where the starter jet/fuel enrichener gets its fuel from, if clogged, no fuel, no start!!
                    Soak the other hard parts, jets, nozzle, etc. in cleaner, or use a toothbrush and spray cleaner and make sure ALL of the little holes in the sides of the pilot jet and main nozzle are clear and open!
                    Sitting for years with fuel in them, the gas gums and varnishes, and really clogs all of these little openings restricting or preventing fuel flow....possibly why it won't start or fire!?
