Alternator cover is Hot !!??
  • gaffer77
    • Jul 2004
    • 444
    • gloucestershire england
    Hi
    I have just spent a year rebuilding my bike ,,it is 79 3h3 SF engine
    2h9 alternator and cover (uk 1978 E model)
    Anyway after starting it up for the first few times (just in the shed ,,not been up the road yet) I found the Alternator cover quite Hot to touch ,,hotter than the crank case it is bolted to
    The Stator did have some corrosion on it i am afraid,, eeek !!
    Anyway can anybody tell me if i am looking at trouble ??
    do they normally get very hot (i presume NOT!!)
    and what should i look at
    any help on this i would be very gratefull of as it is booked on the Ferry in June for the European French XS1100 Rally ,,and time is not on my side
    Cheers
    Gaffer
    Don't put all yer eggs into one basket ,,,case
  • mro
    • 4276
    • Hayward, California
    If it were caused by friction, (rotor rubbing) would think you would hear it.
    If caused by a short in the field, would think it would not be generating (charging) properly, so....
    Have you checked the voltage out put?
    mro
    • gaffer77
      • Jul 2004
      • 444
      Hi mro ,,should have done those things before askin the question really i guess ,,just had so many issues with it ,,didn't have the energy to look further into this just yet ,,,so thought get the advice first and look later ,,if you know what i mean
      Thanks anyway will go check it soooooon
      Gareth
      • TomB
        • 967
        • Cumbria, UK
        mro has a good point there Gaffer
        Try a meter across the battery and rev the motor to see if you get up to 13.5-14V
        Tom
        • gaffer77
          • Jul 2004
          • 444
          Hi Tom
          Will do ,,hmmmmmmm Saddo just said Andy P had the same sort of thing ,,his was shorting on the cover (which you told me to check ,,,,,,,,,,i know ,,,,,,,,but you know what a rollercoaster i been on ,,)The thought of removing the newly fitted crash bar just don't enthuse me much ,,,today at least anyway ,,,,,,,,ha ha !!
          Everytime it looks nearly built and complete ,,,i got to strip it all down again ,,,grrrrrrrrr!! (goes with the territory i know ) ha ha !!
          Gaffer
