Finally Got My Oil Cooler Hooked Up
  • XMRGWX
    • Jan 2007
    • 48
    • New Jersey
    Project oil cooler started more than 20 years ago. I worked at a Yamaha shop at the time and decided to put an oil cooler on the XS Eleven. I ordered a FJ 1100 oil cooler, hoses and the XS850H adaptor plate. It looked like a fairly simple install until I tried to hook up the oil lines. That damn cross brace on the XS 11 was right in the way. I tried re-bending the lines with less than satisfactory results. This is where the project stalled. I started some other things an never got back the cooler.
    Last week while cruising 70 mph and seeing the oil temp at 225 on an 80 degree day I decided one way or another that cooler was going on this year. Instead of modifying the old hoses I went with all new ones with AN-10 fittings. The first order of business was coming off that 850 plate nice and clean (and hopefully leak free). I made and adaptor block to handle this. It has "O" ring seals on the front to match the adaptor ports and 3/8" pipe threads on the back. There is an offset downward maybe 3/8" for extra clearance with the cross member. The block is OK but the fittings looked like they would be on the close side. Off the block is 2 3/8" male thread to AN-10 adaptors onto which the el's attach. The second piece of business was coming off the FJ cooler. It's designed for "O" ring seals so two more adaptor blocks needed to be made. These have "O" rings in the front and 3/8" female pipe threads in the rear, again offset downward slightly for connector clearance.
    Making the lines up was fairly easy and I was on the road in no time. That FJ cooler is really nice, it's set up for rubber mounting, it's all aluminum and has monster ports in and out. Because of the dimensions extra wide and only 2 1/2 high not much air is blocked from the cylinders. The one problem I ran into was it worked too well. If the outside temp was only 62 degrees I could not get the oil temp past 145 - 150. Originally my goal was to keep it simple and run without any thermostat but I could see after a couple of times out that wasn't going to work. Back to the drawling board. There were a few of the automatic thermostat units out there, but I wanted full control. The last thing to do was make a cable controlled diverter valve. There's not a lot to it, 3/8" pipe threads in and out and a few "O" ring seals. The valve mixes temps so you can dial it in anywhere in between full cooler to full bypass.
    Now I'm in XS 11 heaven. The other day I watched the temp go from a little over 200 on bypass to 170 on the cooler the air temp was maybe 74. Warm up time is greatly reduced and that FJ cooler work better than I would have guessed.
    For those contemplating a cooler - go for it. You wont believe the difference. The engine even runs smoother.
    The moral of my tale of woe I guess would be, if at first you don't succeed try try again.
    Long Live the XS1100
    78 XS1100E
    85 VMax
    • 5048
    It looks good. Nice and need.
    • 79XS11F
      • 3563
      • Ottawa, Ont. Canada
      Nice job and nice attention to detail :-)
      Rob
      KEEP THE RUBBER SIDE DOWN
      1978 XS1100E Modified
      1978 XS500E
      1979 XS1100F Restored
      1981 Suzuki GS1100
      1983 Suzuki GS750S Katana
      1983 Honda CB900 Custom
      • mrutah12
        • 105
        • back in utah
        nice job
        thats nice xschop will like how thats done i guess . one question how did you attach it to the oil filter housing and one more question how much would you charge to make those adapters for somebody like me that dosent know anything about machining
        4/78 xs1100 standard
        Pacifico fairing 4 into one exhaust
        new name :black Knight
        I am but a student in this world of xsive masters
        • mro
          • 4276
          • Hayward, California
          I've been convinced that the coolers are a good idea, even tho I've put thounds of miles on the G last year through all kinds of temps... without any problems. Now just need to get off my lazy a$$ and install one.
          Valve you added is a real nice touch
          mro
          • tommystinson
            • Aug 2003
            • 425
            • Albany, NY
            Wow! That is a trick setup if there ever was one. Beautiful work!
            2010 Kawasaki Z1000
            1979 SF: Millennium Falcon, until this Saturday
            • prometheus578
              XS-XJ Super Guru (RESIGNED)
              • Aug 2004
              • 4012
              • Olympia , Wa.
              "Blinded by the Brilliance."
              I was reading his post, as my computer slowly loaded the pictures...
              He doing what...? Connecting where...? tubes and elbow fittings...
              I hate to see what this "Goat-Screw" is gonna look like...
              Behold Gentlemen! The work of a "Master Tinkerer".
              (Not that my opinion ever amounted to much, but this is truly impressive!)
              • randy
                • Dec 2003
                • 4521
                Hey, couldn.t you find a more complicated way to do that?
                Seriously, though, that's fine work, few of us could ever hope to duplicate.
                  • 5048
                  oh.... I meant "Nice and neet." I am in typo hell.
                  • prometheus578
                    • Aug 2004
                    • 4012
                    • Olympia , Wa.
                    And you still haven't left yet!"
                    Neat... nice and NEAT
                    • XMRGWX
                      • Jan 2007
                      • 48
                      • New Jersey
                      Wow! Thanks everyone for the comments and humor.
                      mrutah12
                      The adaptor block is bolted to the XS850 adaptor plate with (4) 6 x 30 allens. At this time I'm not planning on making and sellling adaptor blocks, maybe later on if there's interest. So far so good but nothing beats 5 or 10 thousand miles to shake out any possible unanticipated problems.
                      78 XS1100E
                      85 VMax
                      • randy
                        • Dec 2003
                        • 4521
                        Mike,
                        You coming to the Pulaski, NY rally?
                        • XMRGWX
                          • Jan 2007
                          • 48
                          • New Jersey
                          I really doubt it Randy. I've got a couple of things I need to get done on the eleven before going long distance.
                          78 XS1100E
                          85 VMax
