Ok, slightly cryptic title to drag your attention in here for my question.
Been having a discussion with a mate on the difference float levels make to rich/lean conditions.
Now I've never paid much attention to float levels as I've always seen the floats as a simple fuel delivery device to keep things running.
Ie Set too low and run out of gas at WOT
And set too high, flooding, stains, pool on the floor etc.
Now to the hard part of my comprehension.
How does 1-2 mm make a difference in a carb bowl that is essentially sealed from the carb throats with the exception of the main jet and starter tube.
Now both of these fuel intakes are taken from the bottom 5 mm of the bowl so I don't understand how a few mm on the level can make a difference.
Lifting the fuel level still means the feed has to go through the main/pilot jet orifice so why does it make a difference.
Cheers
HG
Cheers
HG
will chime in with,
