rattley exhaust
  • procamper
    • Aug 2002
    • 68
    • slinger wi
    rattley exhaust
    the number three downpipe has started to rattle. the studs are as tight as i feel comfortable making them (to the torque spec but dont want to get overzealous with 25 year old studs)
    I think the problem could have come from removing that side to weld up a crack on the collector. has anyone else had to replace the seals after removing the pipes once? anyone have a good source for the exhaust gaskets?
    thanks
    79ish suzuki rm250
    82 honda cb450sc
    78 honda cx500
    72 honda cb175
    78 yamaha xs11e
  • Snow
    • Oct 2002
    • 1041
    • Tallahassee, FL
    I *believe* you can still buy yamaha oem gaskets, there are also several aftermarket sources but from my personal experience (may just be me) they are about the same price.
    Dennis Kirk has them in stock for $1.99 each
    XS11 Gasket from Dennis Kirk
    But I would suggest calling your local Yamaha dealer first, they just might have them in stock.
    • nashville_bill
      • 605
      • Nashville, TN
      You can get the exhaust gaskets from www.partsnmoreonline.com for $4 per set of four.
      Bill Murrin
      Nashville, TN
      2005 DL1000 V-Strom "WOW"
      2005 FJR1300 Newest ride
      • Snow
        • Oct 2002
        • 1041
        • Tallahassee, FL
        Nice - I'll have to order a couple sets from them
        Also, just noticed the year range on the Vesrah's at DK is 79-81, not sure if they are the same part for 78 or not :/
        • oldfart
          • Aug 2002
          • 84
          • North Bay,Ontario,Canada
          exhaust rattle
          they should be regarded as a onetime use only gasket, to prevent leaks and rattles and provide a good seal.They are very inexpensive.....Will
          • procamper
            • Aug 2002
            • 68
            • slinger wi
            well, i fixed it...
            was going to try to loosen the manifold bolts to take a look at the seals, but put just a hair two much torque on one and it snapped right below the nut. Of course it was the stud that is almost right behind the frame tube so it was a pain in the butt to get the drill bit straight enough to make a hole for the easy out
            managed to get it out with liberal doses of heat, wd40, and cussing. Now its set for tommorow-supposed to be a high of 65!! woo hoo!
            new gaskets are on the shopping list for this winter--ill have to take of the pipes to do some painting anyways, so ill do it then.
            79ish suzuki rm250
            82 honda cb450sc
            78 honda cx500
            72 honda cb175
            78 yamaha xs11e
