Transmission washer replacement?
  • NemisusDM
    • Oct 2006
    • 147
    • Carmel, NY
    Hello,
    Since Yamaha no longer carries the 2nd gear washer, where can I get a replacement washer? Does it have to be hardened steel? Someone has to be making washers with the same measurements....
    ID-30.2mm
    OD-36.0mm
    Thickness-1.0mm
    Thanks,
    1979 XS1100SF "Sakura Natsuhiboshi"
