Right Sidecover grommet
  • underdog57
    • Jul 2006
    • 321
    • Alburgh , Vermont,054
    Hi guys ,
    Would like to know what the grommet looks like for the right sidecover on the 79 special ...I know I can order it , but was wondering what it looks like ...
    Thanks
    Bob
    1979 XS1100 SPECIAL (under 18,000 miles Sold 5/12/2016
    1982 XJ1100 MAXIM(PARTS BIKE??)shows 14,000 miles ??? Up for sale whole or parts
  • Lamric
    XStremely XSive(Deceased)
    • 410
    • Kenley, Surrey, England
    This grommet is from the right side panel of an SF, it's Yamaha Part Number 90480-01141-00
    There's 1,700 photos of XS1100 parts on my XS Part Number Finder website.
    Brian
    • John
      • 5117
      Sorry Lamric
      The grommets in the pic are for an 80-81 Special. The 79 SF had the slotted side covers, not the round openings that these fit. However, the lower grommet is like the one pictured.
      • Lamric
        • 410
        Sorry if there was any confusion. The part number I gave (90480-01141-00) is for the grommet circled in red. This is used across the models.
        Underdog57: The SF side panel is held on by a grommet and two rubber dampers. In case you meant the two dampers (2H7-21717-00-00), this is what they look like .
        Brian
        • underdog57
          • Jul 2006
          • 321
          Hey Brian ,
          Thanks for taking the time to post ..
          I can get the grommet , did not know about the dampeners ...
          will order them if I can , the left side must take the dampeners too..
          Too bad the one owner PO missplaced a few parts , can't complain . Took it for inspection and it passed ..Po put new tires on before I got it even ..
          Bob
          • Ken Talbot
            • 4251
            • Revelstoke, BC
            If you can't get the dampeners, you can use some industrial grade cyanoacrylate glue (superglue) and stips of rubber cut from an old inner tube to build up a rubber dampener on the metal tab on the frame. This works as well as the real thing.
            Ken Talbot
            • underdog57
              • Jul 2006
              • 321
              I see the parts list has the dampners only on the rear tabs.?
              They look unavailable , will do the innertube method ..
              Thanks for the tip !
              Bob
