Octane requirment
  • Douglas Money
    • Jun 2006
    • 180
    • Braidwood IL
    In the Chicagoland area in 1979, regular gas was 89 octane.
    1979 XS1100F (runnin the wheels off it)
    1979 XS650 (ran the wheels off it)
    1976 CB550F (ran the wheels off it)
    • xsrider
      • Dec 2003
      • 49
      • Cassadaga, NY
      Yes, but what about unleaded... these engines were designed to run on leaded regular, and the lead part lubricates the valve guides and stems etc.... anyone have some experience to share?
      tim correy
      Cassadaga NY
      80 Special "Big Nasty"
        At the local YammyHammer shop, they have some leaded racing fuel that's rated at 110 octane... I also know a local station that has unleaded racing fuel grades of 100, 105, and 110. It's about 7 bucks a gallon, but have been tempted at times to fill up and see what happens. Is there a possibility of too high octane?
        • randy
          • Dec 2003
          • 4521
          I don't know, in the mid-70's when Sunoco still sold their 260, whenever i used it seemed it made a difference. maybe it was my imagination?
          Anyone else remember Sunoco 260? IIRC, the octane was 102 right outta the pump.
          • Douglas Money
            • Jun 2006
            • 180
            • Braidwood IL
            Higher octane requires more timing. If you don't advance the timing to take care of the higher octane you will see only a slight to no improvement.
            • Douglas Money
              • Jun 2006
              • 180
              • Braidwood IL
              BTW, the lead is only to cushion the valve seats and faces for high valve spring pressure. The hardened valves used today do not need the lead. I don't know what the 1100 used in this case.
              • scott0757
                • Jun 2007
                • 130
                • Syracuse, NY
                Not only do I remember Sunoco 260 I remember pumping it for a summer job. You could rorate the grade setting from 86 up to 260. Does anyone remember the Sunoco CAM2 racing fuel???
                Past Rides:
                1969 OSSA 250 Pioneer
                1979 XS650 Special
                1978 Honda CB750K
                Current: 1980 XS1100SG
