Oil cooler...
  • Oil cooler...
    I purchased an oil cooler and it has an adaptor plate with both hoses coming out side by side on the front. I had a different one on the '79 that had the hoses mounted on opposite sides. I thought this one would work, but the fittings for the tubes and hoses have to go right through the lower frame crossmember.
    Does anyone know what model this cooler is for?
    If it fits yours, it's for sale and/or if you have one for a '78 E model that you would like to sell............
    Drilled airbox
    Tkat fork brace
    Hardly mufflers
    late model carbs
    Newer style fuses
    Oil pressure guage
    Custom security system
    Stainless braid brake lines
    If it's an OEM-type cooler plate then it's off an XS850.
    It can be modified to work but you'll have to modify the lines.
    Another lister here cut off the metal tubes and brazed a ridge on the end of the tube to hold a rubber line on.
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
      Noroom
      There is no room to do anything there. It's just too close to the frame member.
      Drilled airbox
      Tkat fork brace
      Hardly mufflers
      late model carbs
      Newer style fuses
      Oil pressure guage
        Can you post a pic, Dick? That may help ID the plate.
        That was me that brazed a ridge on the cut steel lines for an 850 cooler setup.
          John, did you also turn the fittings upside down?
          Pat Kelly
            Un-cool cooler
            I sold em the cooler.
            Was supposed to be off an XS11
            Will check my other spare cooler aginst one I have mounted on a standard to see whats up.
            mro
              lockhart?
              that's probably a lockhart one. Sounds like the one on Bluestreak. The PO has 145 deg brass fittings that route the oil lines past the frame there....I am currently looking for an extra cooler base for a diff Mod....
              MDRNF
              79F.....Not Stock
                Yes, I did, and then routed the hoses up along the frame rails.
                  Other cooler
                  Had planned on changing brass fittings on this one
                  mro
                    Now that looks like a Lockhart adapter plate.
                      New one....
                      I found a new oil cooler, still in box.... with warrenty
                      I'm so lucky and have good friends... Cost me $20 it even has a temp control system so it is good even in the winter.
                      Drilled airbox
                      Tkat fork brace
                      Hardly mufflers
                      late model carbs
                      Newer style fuses
                      Oil pressure guage
                        sunnyday
                        Whats the model # of the derale cooler?
                        where'dya "find" it.
                        i've had my eye out for the oil plate.
                        One of a kind SF
                        (Do not take advice from this man)
                        • #13
                          i apologize,
                          whats the model number derale for the kit?
                          was the adaptor plate part of the kit?.
                          model #
                          One of a kind SF
                          • #14
                            All included as in the pic.
                            Part # Y-1T and according to the box the company is in Gardena, CA
                            Here's the bike pic as requested...
                            Just as it was after the Laughlin River run, 604 miles of smashing bugs at over 100 MPH!!!
                            Drilled airbox
                            Tkat fork brace
                            Hardly mufflers
                            late model carbs
                            Newer style fuses
                            Oil pressure guage
                            • #15
                              most XSellant bug smasher
                              mro
                              btw,
                              have you ever encountered a 50 mph cross wind when your moving that fast?
