Changing out the tires need tips on proper grease
  • OpFlash
    • Feb 2005
    • 197
    • Chicago
    Hey guys im changing out the tires on my XJ and im wondering what type of grease i should use to relubricate the gears on the shaft drive and what kind of grease i should use on the axle. The manual states use a light coating of lithium base grease to the final gear case splines and rear wheel hub splines. what brand or type do you recommend? Can I get it at the regular auto parts store? Thanks
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    any decent automotive grease will do, read you repair manual, just stay away from crisco or lard
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
    • HobbyMan
      MeatHead Idiot "GURU"
      • 1801
      • Colleyville, TX
      Molly B. Do not mix grease types. I use molly because that is what is called for most of the time and it has many good properties
      Acta Non Verba
      • mason79
        • Mar 2006
        • 1359
        • los angeles, ca
        aren't blends a mix, anyways?
        History
        85 Yamaha FJ 1100
        79 yamaha xs1100f
        03 honda cbr 600 f4
        91 yamaha fzr 600
        84 yamaha fj 1100
        82 yamaha seca 750
        87 yamaha fazer
        86 yamaha maxim x
        82 yamaha vision
        78 yamaha rd 400
        • HobbyMan
          • 1801
          • Colleyville, TX
          I am not sure if that is always what it is. I have been told by many people that you are not supposed to mix grease types.
          Acta Non Verba
          • mason79
            • Mar 2006
            • 1359
            • los angeles, ca
            then he should clean the old stuff off, good idea?
            History
            85 Yamaha FJ 1100
            79 yamaha xs1100f
            03 honda cbr 600 f4
            91 yamaha fzr 600
            84 yamaha fj 1100
            82 yamaha seca 750
            87 yamaha fazer
            86 yamaha maxim x
            82 yamaha vision
            78 yamaha rd 400
            • BLUEJEEPLAB
              • Sep 2005
              • 703
              • Miami Valley, Ohio
              It's always a good idea to clean up as much of the old as you can since grease tends to trap metal frags and contaminants.
              Papa Gino
              79 and something XS 1100 Special "Battle Cruiser"
              78 XT 500 "Old Shaky"
              02 Kawasaki Concours "Connie"
              • TADracer
                • 1417
                • Kenner, Louisiana USA
                Molyebdenum Disulfide
                I'm not a grease wizard by any stretch of the imagination but the factory recommends Molyebdenum Disulfide grease on the wheel bearings, drive shaft splines and other places.
                Part of the lubrication properties of grease comes from the microscopic metal that is within and Moly is some slipery stuff. Other automotive grease blends use metals such as aluminum and that might not be well suited for some reason.
                Moly Disulfide is readily available at auto parts stores and I would take care to clean all traces of old lubrication from bearings and joints before applying new grease. Dis the same thing a few weeks ago when I changed tires and that is a great time to do this.
                Have fun.
                Mike Giroir
                79 XS-1100 Special
                  • 7818
                  And I have to be different! I use Redline or Mobil One synthetic grease for everything. I've never had a problem, and it is more waterproof than standard wheel bearing grease, and has a higher drop point.
                  Just my $0.02
                  • HobbyMan
                    • 1801
                    • Colleyville, TX
                    see that is why I use molly b also. It is recomended by the factory. I think it has greater strength against corrosion or something.
                    Acta Non Verba
                    • mason79
                      • Mar 2006
                      • 1359
                      • los angeles, ca
                      yeah i had a can of that; that literally lasted for 20 years, the xs 1100 used up the last bit, i recently bought synthetic blend, i trust it to do the job...
                      History
                      85 Yamaha FJ 1100
                      79 yamaha xs1100f
                      03 honda cbr 600 f4
                      91 yamaha fzr 600
                      84 yamaha fj 1100
                      82 yamaha seca 750
                      87 yamaha fazer
                      86 yamaha maxim x
                      82 yamaha vision
                      78 yamaha rd 400
