Stupid Question
  • frogdink
    • Feb 2007
    • 146
    • Richmond, Maine
    Stupid Question
    is it normal for the somewhat loud sound when i shift on the xj1100. i have talked to some people that say that it is just because it is shaft driven, and i have talked to others that say it needs to be checked out. i changed the gear oil last year and it made no change at all. so is it normal....ot is this a big problem. everything works fine as far as going through the gears, no problems at all, just the sound, and its not that bad, just a loud, click/grind type of a sound....any ideas??? thanks alot. -Joe
    1982 XJ1100J
    Sold:
    1974 RD200
    1975 xs500
    1985 Honda XR350
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    clutch
    probly adjust your clutch at the lever for more release...
    MDRNF
    79F.....Not Stock
    • frogdink
      • Feb 2007
      • 146
      • Richmond, Maine
      Is there an easy way to explain how to do that? never really messed around in that area.
      1982 XJ1100J
      Sold:
      1974 RD200
      1975 xs500
      1985 Honda XR350
      • xschop
        • Feb 2006
        • 1794
        • oklahoma city
        knob
        round knob on your clutch perch, tighten the cable with that....
        MDRNF
        79F.....Not Stock
          Hey Frog,
          There are 2 places to adjust your clutch, one at the engine cover, the other is at the handlebar. You need to set the engine one first, and then the handlebar one. There is a TECH TIP(hint) that tells you how to adjust the clutch engine side.
          These trannys ARE very clunky, square cut gears, etc.. I had a friend riding behind me for the first time and he thought he was going to see tranny parts flying out after he heard me shifting, and I "USE" the clutch!
          But getting it up to the proper rpm before shifting and blipping the throttle and pulling the clutch in can make the shifts smoother and quieter, but also different grades of oil can also quiet it!
          • HobbyMan
            MeatHead Idiot "GURU"
            • 1801
            • Colleyville, TX
            The adjustment on the handlebar is strictly a free play adjustment.
            Acta Non Verba
            • frogdink
              • Feb 2007
              • 146
              • Richmond, Maine
              thanks
              i will try these things. thanks a lot guys.
              1982 XJ1100J
              Sold:
              1974 RD200
              1975 xs500
              1985 Honda XR350
