blown main fuse?
  • edgo
    • Jul 2005
    • 138
    • Tampa FL
    blown main fuse?
    I was riding to work today and the bike went completely dean while idlign at a stop light. A few days ago I had taken apart the headlight to lube my tach. I had tach wobble but it is fixed. Before the bike died the left tunr signal quit. All the fuses under the right panel are good. I'm guessing that when I messed with the headlight I coused a wire in the left turn signal circuit to short the main fuse? How's that sound? I walked on to work and the bike is sittings two blocks up the street.
    Ed
    79 XS1100SF
    78 YZ400E
    81 SR500
    79 RM250
    77 YZ400D
    05 RM250
    78 CR 250 Husky w/TT500 motor
    Hey Edgo,
    The turn signals draw lots of power, hence their 20 amp fuse vs. all the others. IF it quit working or blinking, then the power was dropping. Possibly you have a power charging problem? Once the battery gets below ~10.5 volts, the TCI quits working and the bike will die!
    A short isn't out of the question, there are some HOT all the time wires in the headlight, as well as switched, and you could have a simple short? Could also have a slow drain? Also don't forget to check the kill switch on the handlebar. PULL your fuses, and check with continuity meter, don't just LOOK at them!
    Also, the tip over emergency cutoff switch under the tank that says "UP" on it can also go bad, can pull/unplug it to check/bypass! Good Luck!
    • edgo
      • Jul 2005
      • 138
      • Tampa FL
      I have spare fuses and tried changing all the ones on the right side. The bike has a new battery that turned it over really fast when I started it up ten minutes before it died. When I turn on the ignition now it is completely dead, no indicator lights come on.
      Thanks
      79 XS1100SF
      78 YZ400E
      81 SR500
      79 RM250
      77 YZ400D
      05 RM250
      • edgo
        • Jul 2005
        • 138
        • Tampa FL
        I did have right side blinkers before it died.
        Ed
        79 XS1100SF
        78 YZ400E
        81 SR500
        79 RM250
        77 YZ400D
        05 RM250
        • papanovember
          • 137
          When you lubed the tach connection, did you loosen any other connections? Check your ignition switch connection. If that has come apart, then you wouldn't get any power when you turn the key on. Also, there is a main power wire that comes off the battery and into the wiring harness. It is under the right sidecover. Check the connection there. I recently had to redo my connection on that wire. I had the same symtoms that you are experiencing.
          • edgo
            • Jul 2005
            • 138
            • Tampa FL
            It turns out that the left blinker wire was disconnected in the headlight bucket. I guess it was rattling around and blowing everything. I hooked it up and replaced all the fuses and it is fine. Thanks to all.
            Is the main fuse, the 30 amp one, that black thing next to the right of the fuse block?
            Ed
            79 XS1100SF
            78 YZ400E
            81 SR500
            79 RM250
            77 YZ400D
            05 RM250
            • 79XS11F
              • 3563
              • Ottawa, Ont. Canada
              NO ... The main fuse is in the box.
              KEEP THE RUBBER SIDE DOWN
              1978 XS1100E Modified
              1978 XS500E
              1979 XS1100F Restored
              1981 Suzuki GS1100
              1983 Suzuki GS750S Katana
              1983 Honda CB900 Custom
              • DeanR
                • Jan 2005
                • 1490
                • Finger Lakes NY
                That's an accessory fuse. Main fuse is on the other side for some reason, behind the left side cover.
                80 SG
                81 SH in parts
                99 ST1100
                91 ST1100
                  Hey Dean,
                  The differences in the years got you, Rob was right, the main fuse is in the fuse block in the early models, in the later models, it was put on the left side in a separate holder!
                  Glad you found the problem Edgo! Don't know what your extra fuse holder is, the main is supposed to be one of the 4 fuses in your box!?
                  • DeanR
                    • Jan 2005
                    • 1490
                    • Finger Lakes NY
                    oops...... hadn't seen rob's post yet, and., I didn't know that there was a fuse difference between years anyway!
                    80 SG
                    81 SH in parts
                    99 ST1100
                    91 ST1100
                      That's okay Dean,
                      You're only 1/2 way to GURU status yet, by the time you get there you'll know these things!
                      • DeanR
                        • Jan 2005
                        • 1490
                        • Finger Lakes NY
                        Geez TC. I'm always here asking questions, and just when I think I can contribute and answer something, I blow it!!
                        80 SG
                        81 SH in parts
                        99 ST1100
                        91 ST1100
                        • edgo
                          • Jul 2005
                          • 138
                          • Tampa FL
                          Blow it is right. I spent six hours looking under the left cover for a fuse.
                          ED
                          79 XS1100SF
                          78 YZ400E
                          81 SR500
                          79 RM250
                          77 YZ400D
                          05 RM250
                          • DeanR
                            • Jan 2005
                            • 1490
                            • Finger Lakes NY
                            Hey edgo
                            Six hours to look for a fuse huh?? Please accept my apology...
                            80 SG
                            81 SH in parts
                            99 ST1100
                            91 ST1100
                            • edgo
                              • Jul 2005
                              • 138
                              • Tampa FL
                              Maybe it was six minutes. I did take the tank and seat off and check all the connectors just for good measure.
                              This bike had been going perfect for over a year since I got it going. Does this episode count as a breakdown? It was my screwup.
                              Ed
                              79 XS1100SF
                              78 YZ400E
                              81 SR500
                              79 RM250
                              77 YZ400D
                              05 RM250
