reserve never flow problem
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    i noticed what ever i do with the fuel lines below, i can't seem to get the reserve on either left stock vacuum petcock nor my right manual petcock to feed gas while at the reserve level.
    they are t'd to a filter and t'd to off of that to feed the carb in's.
    my experiment was to run it all the way down to reserve and like a normal situation flip that bitch and behold gas, but...no such luck, i coasted to a dead still and had to pour the gallon can into the tank just to get started and i had a scare cause it just cranked,
    and i was on the shoulder of an uphill facing freeway with no out, a pickup truck pulled over and guy walked up to me, i hit the button again after, i primed the left petcock,and it fired, ran flawlessly with gas. thanked the man and rode off like an xs should and did.
    why did the manual petcock not feed gas, help! this is my third replumb in all confirgurations and not to access reserve, is not good.
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
  • 81xsproject
    • 3185
    • Fortuna, CA
    Maybe the screen towers came off and aren't there to stop the "ON" flow until all the gas is gone?
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
    • mason79
      • Mar 2006
      • 1359
      • los angeles, ca
      huh?
      the mike's xs petcock has long and short snorkels to capture gas at differnet level, taller for yada yada.
      yeah one cheap screen fell off of that, , i don't think it matters.
      the stock petcock(vacuum) has screens intact.
      History
      85 Yamaha FJ 1100
      79 yamaha xs1100f
      03 honda cbr 600 f4
      91 yamaha fzr 600
      84 yamaha fj 1100
      82 yamaha seca 750
      87 yamaha fazer
      86 yamaha maxim x
      82 yamaha vision
      78 yamaha rd 400
      • 79XS11F
        • 3563
        • Ottawa, Ont. Canada
        If there's still gas in the tank but no flow on reserve then perhaps the lower fuel supply section or of the screens is plugged. Does "prime" work?
        Rob
        KEEP THE RUBBER SIDE DOWN
        1978 XS1100E Modified
        1978 XS500E
        1979 XS1100F Restored
        1981 Suzuki GS1100
        1983 Suzuki GS750S Katana
        1983 Honda CB900 Custom
        • oseaghdha
          • 1075
          • N43.02.5,W88.14.2
          Check for flow on reserve when the tank is full.
          Then you can at least find out if the passages are blocked.
          If that works, maybe there is a problem with the level control.
          XS1100SF
          XS1100F
          • mason79
            • Mar 2006
            • 1359
            • los angeles, ca
            i don't know what you mean by level control, but i went ahead and cleaned out the cap vent, that is a new revelation to me, it appears upplugged but, thank you this site for the old thread.
            and it flow on prime and the manual flow on reserve, i'll check the flow of the vacuum one later, thanks again.
            History
            85 Yamaha FJ 1100
            79 yamaha xs1100f
            03 honda cbr 600 f4
            91 yamaha fzr 600
            84 yamaha fj 1100
            82 yamaha seca 750
            87 yamaha fazer
            86 yamaha maxim x
            82 yamaha vision
            78 yamaha rd 400
            • mason79
              • Mar 2006
              • 1359
              • los angeles, ca
              thanks guys it was the cap vent, i didn't see any obstructions, i guess there was some and low fuel level couldn't overcome the vacuum in the tank.
              History
              85 Yamaha FJ 1100
              79 yamaha xs1100f
              03 honda cbr 600 f4
              91 yamaha fzr 600
              84 yamaha fj 1100
              82 yamaha seca 750
              87 yamaha fazer
              86 yamaha maxim x
              82 yamaha vision
              78 yamaha rd 400
