Hi iwould like to know if i can change the piston rings on my xs1100g with out removing the motor from the from the frame? Thanks
can you
Hi Badrap,
Clymer's sez you can take the barrels off in-frame so I guess you can.
Fred Hill, S'toon.Fred Hill, S'toon
"The Flying Pumpkin" -
Yes, you can. Just have to take the exhaust, carbs and head off, then split the cam chain. then the barrels lift right off.
That is where I am right now, in my repairs.Nice day, if it doesn't rain...
'05 ST1300
'83 502/502 Monte Carlo for sale/tradeComment
No need to split the cam chain unless you want to replace it. Come to think of it, if the rings are shot, chances are that the motor has very high miles? Might as well replace the chain.
Before you pull the motor apart, tell us why you think the rings are bad. There may be another fix that will save you a lot of work.Comment
"Not to split hairs... nor cam chains..."
Randy is correct."Damn it Jim, I'm a doctor, not a mechanic!' ('Bones' McCoy)Comment
